stega
December 9, 2024, 12:22pm
1
RUT906, firmware RUT9M_R_00.07.11.1, after installing the Hotspot package I wanted to use “chilli_query” to change “on the fly” two parameters - maxbwup and maxbwdown for a selected session.
in Hotspot configuration I have set:
interface: RUT906_xxx (not LAN)
mode: MAC authentication
landing page Internal
I executed the commands
root@RUT906:~# chilli_query list sessionid 77e406a06756b55e
E8-5A-8B-0B-BE-09 192.168.2.1 pass 77e406a06756b55e 1 E8-5A-8B-0B-BE-09 9226/0 93/0 16167057/0 2326603/0 0 0 0 0/0 0/0 http://connectivitycheck.gstatic.com/generate_204 vlan=(null)
root@RUT906:~# chilli_query update sessionid 77e406a06756b55e maxbwdown 500000
root@RUT906:~# chilli_query update sessionid 77e406a06756b55e maxbwup 500000
E8-5A-8B-0B-BE-09 192.168.2.1 pass 77e406a06756b55e 1 E8-5A-8B-0B-BE-09 9258/0 29/0 16167900/0 2327955/0 0 0 0 0%/500000 1%/0 http://connectivitycheck.gstatic.com/generate_204 vlan=(null)
From the last command it appears that one parameter was changed (why only one?), but it did not affect the actual transfer speed for this client.
This is important to me, could someone help me with this please.
Thanks in advance for all advice.
stega
December 10, 2024, 7:59am
2
I’ve checked this on the RUT955 with RUT9_R_00.07.06.16 and it works like a charm there
Marija
December 12, 2024, 1:41pm
4
Could you kindly share the output from the RUT955?
Thank you!
stega
December 13, 2024, 8:25am
5
Helo,
Here you are.
As you see the last output shows the changes and the results was confirmed by speedtest-net. Bandwidth was decreased according to settings.
Hope this help you solve the problem on RUT906.
root@RUT955:~# chilli_query list mac 3A-F5-07-C6-DD-70
3A-F5-07-C6-DD-70 192.168.2.11 pass 3b9aca0000000000 1 3A-F5-07-C6-DD-70 137/0 55/0 73521/80000000 26175/20000000 0 0 0 0%/3000000 0%/5000000 http :// connectivitycheck.gstatic .com/generate_204 vlan=(null)
root@RUT955:~# chilli_query update ip 192.168.2.11 maxbwup 100000
3A-F5-07-C6-DD-70 192.168.2.11 pass 3b9aca0000000000 1 3A-F5-07-C6-DD-70 169/0 15/0 2176115/0 291066/0 0 0 0 0%/100000 2117%/0 http://connectivitycheck.gstatic .com/generate_204 vlan=(null)
root@RUT955:~# chilli_query update ip 192.168.2.11 maxbwdown 500000
3A-F5-07-C6-DD-70 192.168.2.11 pass 3b9aca0000000000 1 3A-F5-07-C6-DD-70 187/0 0/0 2282411/0 347106/0 0 0 0 35%/0 0%/500000 http :// connectivitycheck.gstatic.com / generate_204 vlan=(null)
Marija
December 16, 2024, 11:12am
6
Could you please confirm if you are still experiencing the issue after upgrading to the latest 7.11.2 firmware version? You can download it here .
stega
December 17, 2024, 9:02am
7
yes, I’m still experiencing the issue after upgrading to the latest 7.11.2
firmware RUT9M_R_00.07.11.2, have a look at below:
B6-C8-99-FA-7D-83 192.168.2.4 pass 77e566a067613aab 1 B6-C8-99-FA-7D-83 50/0 21/0 57272/80000000 38141/20000000 0 0 30000000 0%/2000000 0%/5000000 http://connectivitycheck.gstatic.com/generate_204 vlan=(null)
root@RUT906:~# tc class show dev br-lan
class htb 1:14 root prio 0 rate 5Mbit ceil 5Mbit burst 1600b cburst 1600b
root@RUT906:~# chilli_query update sessionid 77e566a067613aab maxbwup 100000
root@RUT906:~# chilli_query list sessionid 77e566a067613aab
B6-C8-99-FA-7D-83 192.168.2.4 pass 77e566a067613aab 1 B6-C8-99-FA-7D-83 193/0 13/0 1004485/0 80914/0 0 0 0 0%/100000 0%/0 http://connectivitycheck.gstatic.com/generate_204 vlan=(null)
root@RUT906:~# chilli_query update sessionid 77e566a067613aab maxbwdown 100000
B6-C8-99-FA-7D-83 192.168.2.4 pass 77e566a067613aab 1 B6-C8-99-FA-7D-83 219/0 39/0 1004485/0 80914/0 0 0 0 0%/0 0%/100000 http://connectivitycheck.gstatic.com/generate_204 vlan=(null)
and no effect to the client
Marija
December 17, 2024, 9:39am
8
I have sent you a form. Once you complete it, I will contact you privately. For the Ticket ID , please use “10905” .
Marija
December 19, 2024, 6:14am
9
I have forwarded this information to our RnD team. While they investigate, they suggested using the RutOS API , which is the officially supported tool. The chilli_query
command is an open-source utility that may not function reliably.
The API documentation can be found here: Teltonika Networks Web API
Regarding the command, you should execute the following in the terminal:
api get /hotspot/groups/config '{"id":"default"}
Please let me know if you need any further assistance.
Marija
January 9, 2025, 10:27am
10
I have received feedback from our R&D department, and the fix is planned to be implemented in the 7.13 RutOS firmware version.
Thank you for your patience.
system
Closed
February 7, 2025, 12:22pm
11
