RUT901 only acitive FTP connection works - need passive connection to FTP
I had used RUT240 and RUT950 for a while and never had issues hen setting port forwarding in firewall for port 21. Nothing extra had to be set. With RUT901, although the new GUI, port forwarding in FW was not an issue.
But I have an issue when tying to access to FTP server behind RUT901 using passive mode. I always get stuck at reading directory listing. But with active mode FTP everything works.
Here is Total Commander log:
Connect to: (10.04.2024 10:28:33)
hostname=XXX.XXX.XXX.XXX
username=1234
startdir=
XXX.XXX:XXX.XXX=XXX.XXX:XXX.XXX
220 (vsFTPd 2.3.4)
USER 1234
331 Please specify the password.
PASS ***********
230 Login successful.
SYST
215 UNIX Type: L8
FEAT
211-Features:
EPRT
EPSV
MDTM
PASV
REST STREAM
SIZE
TVFS
UTF8
211 End
HELP SITE
214-The following commands are recognized.
ABOR ACCT ALLO APPE CDUP CWD DELE EPRT EPSV FEAT HELP LIST MDTM MKD
MODE NLST NOOP OPTS PASS PASV PORT PWD QUIT REIN REST RETR RMD RNFR
RNTO SITE SIZE SMNT STAT STOR STOU STRU SYST TYPE USER XCUP XCWD XMKD
XPWD XRMD
214 Help OK.
OPTS UTF8 ON
200 Always in UTF8 mode.
Connect ok!
PWD
257 “/”
Get directory
TYPE A
200 Switching to ASCII mode.
PASV ← it gets stuck here
I when i switch over my SIM data card with static address from RUT901 to RUT240 or RUT950 with the same port forwarding settings I have no such issues. Both passive and active FTP works.
I have tried with several firmware version (stock ,latest factory,…) for RUT901 none made any change
What must I set or check?
Thank you.
