This is a simple question but still important to me. I use a RUT901 for a WiFi in my coach. I want to connect it know that it is always on, also when the coach is not switched on. I would like to connect the RUT directly to my 24v accu, but I’m doubting how to do that in a proper way.
The RUT901 has a 4 pin connector for the 220v input.
Would I just cut the 220V cable and connect the cable from the RUT to the accu?
Seems to be simple but I just want to get sure that I don’t destroy the device.
Thanks for advice
If you want to power your RUT901 directly from your 24V battery, you can safely do so by connecting the red cable from the power supply unit (PSU) to the positive (+) terminal of your battery and the black cable to the negative (-) terminal. This should be sufficient to power up the device.
For more detailed information about powering options for the RUT901, please refer to the official documentation here: RUT901 Powering Options.
