RUT50 LAN not work
Hello, I’m currently working on the RUTX50. I can reach the RUT 50 via VPN (Wireguard). There are 4 devices connected to WiFi that are addressed via DHCP and can also be reached. There are 2 heaters connected to LAN ports 1 and 2 that cannot be reached. They also don’t appear in the Teletonika router.
The heaters expect DHCP and everything worked on a Fritzbox.
What am I doing wrong or missing?
When you connect your heaters to the LAN ports, could you please specify the color of the LEDs next to the ports?
You can find the LED color meanings here: RUTX50 Ethernet Port LEDs.
Best regards
Are your heaters expecting PoE?
