Rut361 netmap nat
To make sure we provide the most accurate solution, could you please help us with the details below?
  1. What are the exact firmware versions installed into the devices?
  2. How is the WAN interface configured (routed interface or bridge/VLAN)?
  • NAT operates only on routed interfaces, so this lets us confirm traffic is processed correctly.
  1. Does the WAN-side device initiate connections to the LAN, or does the LAN initiate them?
  • The traffic direction affects how address translation and address resolution are handled.
  1. Are multiple IP addresses or subnets allowed on the WAN interface?
  • This determines the simplest way to make the translated addresses reachable.
  1. Is Proxy ARP available or enabled on the WAN interface?
  • This allows the router to respond on behalf of translated addresses, which is required for subnet 1:1 NAT.
  1. Is reverse path filtering (rp_filter) enabled on the WAN interface?
  • If enabled, valid translated traffic may be dropped before reaching the destination.
  1. Are there any additional NAT or masquerade rules applied on the WAN interface?
  • This helps us ensure no other rules are interfering with the NETMAP translation.
  1. Do you need full two-way (bidirectional) 1:1 NAT, or only inbound access from WAN to LAN?
  • This helps us tailor the configuration to your actual use case.
  1. If possible, could you provide a short packet capture from the WAN interface during a failed connection attempt?
  • This allows us to quickly confirm whether address resolution is working as expected.
Additionally, you can check this thread as the user had a similar topology, that might help you with the setup:
Looking forward to your reply,
Warm regards,
