Continuing this issue. I note, VLAN Routing on a 955 or RUT11 worked fine long ago using separate LAN ports.
360 only has one LAN port.
OS upgraded and tried again: RUT36X_R_00.07.07.1_WEBUI
Different configurations in this version, did not seem complete.
WAN: DHCP, no issues
LAN:
Default: 10.20.1.1/24, NO TAG, eth0, works fine, NO DHCP
VLAN 11:
Add VLAN11, 802.1AD, eth0
Interface:
Add VLAN11 as interface, eth0, 10.20.2.1/24, all traffic TAGGED, No DHCP
Tagged traffic from 10.20.2.0 is not routed to the WAN interface and traffic to the 10.20.2.0 network does not reach the attached LAN Network.
Cannot ping the 10.20.2.1 from any VLAN 11 TAGGED device, but most of time can ping from the upstream Cisco’s on 10.20.1.0.
ARP tables show as incomplete
Tried static route from 10.20.2.0 to 10.20.1.0 and that did not get packets routed to the LAN interface.
All VLAN Default traffic works well.
If this has to be done in CLI can you send me some examples [please include firewall sections].
Many thanks
