thanks! About 2min worth of SystemLog follows:
Tue Jul 18 05:36:40 2023 daemon.notice netifd: mob1s1a1 (2011): Starting network mob1s1a1 using APN: online.telia.se
Tue Jul 18 05:36:40 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,20 --release-client-id wds --modify-profile --profile-identifier 3gpp,1 --profile-name profile1 --roaming-disallowed-flag no --auth-type none --apn online.telia.se --pdp-type ip
Tue Jul 18 05:36:40 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --get-client-id wds
Tue Jul 18 05:36:41 2023 daemon.notice netifd: mob1s1a1 (2011): 20
Tue Jul 18 05:36:41 2023 daemon.notice netifd: mob1s1a1 (2011): cid4: 20
Tue Jul 18 05:36:41 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-ip-family ipv4 --set-client-id wds,20
Tue Jul 18 05:36:41 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,20 --start-network --apn online.telia.se --profile 1 --auth-type none --username --password
Tue Jul 18 05:36:41 2023 user.notice mobile.sh: Received unknown error(1/5): "Unknown error"
Tue Jul 18 05:36:41 2023 daemon.notice netifd: mob1s1a1 (2011): pdh4: "Unknown error"
Tue Jul 18 05:36:41 2023 daemon.notice netifd: mob1s1a1 (2011): Unable to connect IPv4
Tue Jul 18 05:36:41 2023 user.notice mobile.sh: Received unknown error(5/5): "Unknown error"
Tue Jul 18 05:36:41 2023 daemon.notice netifd: mob1s1a1 (2011): Calling "mctl --reboot -i 1-1"
Tue Jul 18 05:36:41 2023 user.notice mobile.sh: Clearing uqmi processes for /dev/cdc-wdm0
Tue Jul 18 05:36:41 2023 daemon.notice netifd: mob1s1a1 (2011): Releasing client-id 20 on /dev/cdc-wdm0
Tue Jul 18 05:36:41 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,20 --release-client-id wds
Tue Jul 18 05:36:41 2023 daemon.notice netifd: mob1s1a1 (2011): Failed to create IPV4 connection
Tue Jul 18 05:36:45 2023 daemon.info mobifd: [gsm.modem0] Config reload initiated
Tue Jul 18 05:36:45 2023 daemon.notice netifd: mob1s1a1 (2219): Stopping network mob1s1a1
Tue Jul 18 05:36:46 2023 daemon.notice netifd: mob1s1a1 (2219): Command failed: Not found
Tue Jul 18 05:36:46 2023 daemon.notice netifd: mob1s1a1 (2219): Command failed: Permission denied
Tue Jul 18 05:36:46 2023 daemon.notice netifd: Interface 'mob1s1a1' is now down
Tue Jul 18 05:36:46 2023 user.warn mwan3-hotplug[2272]: hotplug called on mob1s1a1 before mwan3 has been set up
Tue Jul 18 05:36:51 2023 daemon.info mobifd: [gsm.modem0] Initializing modem. Please wait.
Tue Jul 18 05:36:51 2023 daemon.info dnsmasq[3233]: read /etc/hosts - 4 addresses
Tue Jul 18 05:36:51 2023 daemon.info dnsmasq[3233]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Tue Jul 18 05:36:51 2023 daemon.info dnsmasq-dhcp[3233]: read /etc/ethers - 0 addresses
Tue Jul 18 05:36:53 2023 kern.info Mobile data disconnected (internal modem)
Tue Jul 18 05:36:53 2023 kern.notice Authentication was successful from HTTP 192.168.1.114
Tue Jul 18 05:36:53 2023 daemon.err uhttpd[2166]: vuci: accepted login for admin from 192.168.1.114
Tue Jul 18 05:36:54 2023 daemon.err mobifd: [gsm.modem0] Failed to set CFUN "full"
Tue Jul 18 05:36:58 2023 kern.info kernel: [36344.700929] usb 1-1: USB disconnect, device number 56
Tue Jul 18 05:36:58 2023 kern.info kernel: [36344.706968] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Tue Jul 18 05:36:58 2023 kern.info kernel: [36344.715654] option 1-1:1.0: device disconnected
Tue Jul 18 05:36:58 2023 kern.info kernel: [36344.721033] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Tue Jul 18 05:36:58 2023 kern.info kernel: [36344.729600] option 1-1:1.1: device disconnected
Tue Jul 18 05:36:58 2023 kern.info kernel: [36344.802497] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Tue Jul 18 05:36:58 2023 kern.info kernel: [36344.810999] option 1-1:1.2: device disconnected
Tue Jul 18 05:36:58 2023 kern.info kernel: [36344.816405] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
Tue Jul 18 05:36:58 2023 kern.info kernel: [36344.824978] option 1-1:1.3: device disconnected
Tue Jul 18 05:36:58 2023 kern.info kernel: [36344.830132] qmi_wwan 1-1:1.4 wwan0: unregister 'qmi_wwan' usb-1b000000.usb-1, WWAN/QMI device
Tue Jul 18 05:36:59 2023 daemon.info gsmd[1894]: [__write:1097] warning: [CMM] Write to `1-1 [2c7c:0306]` modem failed: errno 5
Tue Jul 18 05:36:59 2023 daemon.info gsmd[1894]: [common_write_handle:193] warning: [CMM] Failed to send command (0/23 bytes transferred) to `1-1 [2c7c:0306]` modem!
Tue Jul 18 05:37:00 2023 daemon.info gsmd[1894]: [__write:1097] warning: [CMM] Write to `1-1 [2c7c:0306]` modem failed: errno 5
Tue Jul 18 05:37:00 2023 daemon.info gsmd[1894]: [common_write_handle:193] warning: [CMM] Failed to send command (0/23 bytes transferred) to `1-1 [2c7c:0306]` modem!
Tue Jul 18 05:37:00 2023 user.notice /bin/trigger_vuci_routes_reload: vuci reload_routes triggered
Tue Jul 18 05:37:03 2023 kern.info kernel: [36349.511386] usb 1-1: new high-speed USB device number 57 using ehci-platform
Tue Jul 18 05:37:03 2023 kern.info kernel: [36349.684264] option 1-1:1.0: GSM modem (1-port) converter detected
Tue Jul 18 05:37:03 2023 kern.info kernel: [36349.691093] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
Tue Jul 18 05:37:03 2023 kern.info kernel: [36349.699276] option 1-1:1.1: GSM modem (1-port) converter detected
Tue Jul 18 05:37:03 2023 kern.info kernel: [36349.706144] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
Tue Jul 18 05:37:03 2023 kern.info kernel: [36349.714226] option 1-1:1.2: GSM modem (1-port) converter detected
Tue Jul 18 05:37:03 2023 kern.info kernel: [36349.720976] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB2
Tue Jul 18 05:37:03 2023 kern.info kernel: [36349.728989] option 1-1:1.3: GSM modem (1-port) converter detected
Tue Jul 18 05:37:03 2023 kern.info kernel: [36349.735729] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB3
Tue Jul 18 05:37:03 2023 kern.info kernel: [36349.819998] qmi_wwan 1-1:1.4: cdc-wdm0: USB WDM device
Tue Jul 18 05:37:03 2023 kern.info kernel: [36349.835173] qmi_wwan 1-1:1.4 wwan0: register 'qmi_wwan' at usb-1b000000.usb-1, WWAN/QMI device, 06:8d:cf:38:ee:73
Tue Jul 18 05:37:05 2023 daemon.info gsmd[1894]: [__new_modem:618] error: [MODEM_MANAGER] Modem `1-1 [2c7c:0306]` already exists and is registered!
Tue Jul 18 05:37:05 2023 daemon.info gsmd[1894]: [__modem_added:450] error: [MODEM_MANAGER] Unable to initialize `1-1 [2c7c:0306]` modem!
Tue Jul 18 05:37:09 2023 daemon.err mobifd: [gsm.modem0] Failed to get present soft SIM recovery
Tue Jul 18 05:37:09 2023 daemon.err mobifd: [gsm.modem0] Failed to get present CFUN status
Tue Jul 18 05:37:11 2023 user.notice /bin/trigger_vuci_routes_reload: vuci reload_routes triggered
Tue Jul 18 05:37:15 2023 daemon.info mobifd: [gsm.modem0] Config reload initiated
Tue Jul 18 05:37:19 2023 daemon.info mobifd: [gsm.modem0] SMS storage: sm
Tue Jul 18 05:37:19 2023 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with 15 seconds of timeout
Tue Jul 18 05:37:19 2023 daemon.info mobifd: [gsm.modem0] Connected to operator 'Telia FI Telia'
Tue Jul 18 05:37:19 2023 daemon.err mobifd: [gsm.modem0] Failed to get serving cell info
Tue Jul 18 05:37:19 2023 daemon.info mobifd: [gsm.modem0] -CFUN- Functionality: "Full"
Tue Jul 18 05:37:19 2023 daemon.info mobifd: [gsm.modem0] -COPS- Mode: "Auto", operator: "Telia FI Telia"
Tue Jul 18 05:37:19 2023 daemon.info mobifd: [gsm.modem0] -CREG- Mode: "Enabled (with location information)", status: "Roaming", LAC: "4180", cell ID: "36241676", technology: "E-UTRAN"
Tue Jul 18 05:37:19 2023 daemon.info mobifd: [gsm.modem0] -CGREG- Mode: "Enabled (with location information)", status: "Roaming", LAC: "4180", cell ID: "36241676", technology: "E-UTRAN"
Tue Jul 18 05:37:19 2023 daemon.info mobifd: [gsm.modem0] -CEREG- Mode: "Enabled (with location information)", status: "Roaming", LAC: "4180", cell ID: "36241676", technology: "E-UTRAN"
Tue Jul 18 05:37:19 2023 daemon.info mobifd: [gsm.modem0] IP address on PDP context "1": "10.5.167.134"
Tue Jul 18 05:37:19 2023 daemon.notice netifd: Interface 'mob1s1a1' is setting up now
Tue Jul 18 05:37:20 2023 daemon.notice netifd: mob1s1a1 (3181): wwan[3181] Using wwan usb device on bus 1-1
Tue Jul 18 05:37:20 2023 daemon.notice netifd: mob1s1a1 (3181): wwan[3181] Using proto:qmi_wwan device:/dev/cdc-wdm0 iface:wwan0 desc:Quectel EG06
Tue Jul 18 05:37:21 2023 daemon.notice netifd: mob1s1a1 (3181): Using net device: wwan0
Tue Jul 18 05:37:21 2023 daemon.notice netifd: mob1s1a1 (3181): Informing driver of raw-ip for wwan0 ..
Tue Jul 18 05:37:21 2023 kern.info kernel: [36367.672772] qmi_wwan 1-1:1.4 wwan0: mode: raw IP
Tue Jul 18 05:37:21 2023 user.notice root: uqmi -d /dev/cdc-wdm0 --timeout 3000 --wda-set-data-format --link-layer-protocol raw-ip --ul-protocol disabled --dl-protocol disabled
Tue Jul 18 05:37:22 2023 daemon.notice netifd: mob1s1a1 (3181): Starting network mob1s1a1 using APN: online.telia.se
Tue Jul 18 05:37:22 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,20 --release-client-id wds --modify-profile --profile-identifier 3gpp,1 --profile-name profile1 --roaming-disallowed-flag no --auth-type none --apn online.telia.se --pdp-type ip
Tue Jul 18 05:37:23 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --get-client-id wds
Tue Jul 18 05:37:23 2023 daemon.notice netifd: mob1s1a1 (3181): 20
Tue Jul 18 05:37:23 2023 daemon.notice netifd: mob1s1a1 (3181): cid4: 20
Tue Jul 18 05:37:23 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-ip-family ipv4 --set-client-id wds,20
Tue Jul 18 05:37:23 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,20 --start-network --apn online.telia.se --profile 1 --auth-type none --username --password
Tue Jul 18 05:37:23 2023 user.notice mobile.sh: Received unknown error(1/5): "Unknown error"
Tue Jul 18 05:37:23 2023 daemon.notice netifd: mob1s1a1 (3181): pdh4: "Unknown error"
Tue Jul 18 05:37:23 2023 daemon.notice netifd: mob1s1a1 (3181): Unable to connect IPv4
Tue Jul 18 05:37:23 2023 user.notice mobile.sh: Received unknown error(5/5): "Unknown error"
Tue Jul 18 05:37:23 2023 daemon.notice netifd: mob1s1a1 (3181): Calling "mctl --reboot -i 1-1"
Tue Jul 18 05:37:23 2023 user.notice mobile.sh: Clearing uqmi processes for /dev/cdc-wdm0
Tue Jul 18 05:37:23 2023 daemon.notice netifd: mob1s1a1 (3181): Releasing client-id 20 on /dev/cdc-wdm0
Tue Jul 18 05:37:23 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,20 --release-client-id wds
Tue Jul 18 05:37:24 2023 daemon.notice netifd: mob1s1a1 (3181): Failed to create IPV4 connection
Tue Jul 18 05:37:26 2023 daemon.info mobifd: [gsm.modem0] Config reload initiated
Tue Jul 18 05:37:27 2023 daemon.info mobifd: [gsm.modem0] Initializing modem. Please wait.
Tue Jul 18 05:37:28 2023 daemon.notice netifd: mob1s1a1 (3405): Stopping network mob1s1a1
Tue Jul 18 05:37:28 2023 daemon.notice netifd: mob1s1a1 (3405): Command failed: Not found
Tue Jul 18 05:37:28 2023 daemon.notice netifd: mob1s1a1 (3405): Command failed: Permission denied
Tue Jul 18 05:37:28 2023 daemon.notice netifd: Interface 'mob1s1a1' is now down
Tue Jul 18 05:37:29 2023 user.warn mwan3-hotplug[3456]: hotplug called on mob1s1a1 before mwan3 has been set up
Tue Jul 18 05:37:33 2023 daemon.info mobifd: [gsm.modem0] Initializing modem. Please wait.
Tue Jul 18 05:37:35 2023 daemon.info dnsmasq[3233]: read /etc/hosts - 4 addresses
Tue Jul 18 05:37:35 2023 daemon.info dnsmasq[3233]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Tue Jul 18 05:37:35 2023 daemon.info dnsmasq-dhcp[3233]: read /etc/ethers - 0 addresses
Tue Jul 18 05:37:36 2023 kern.info Mobile data disconnected (internal modem)
Tue Jul 18 05:37:41 2023 kern.info kernel: [36386.976291] usb 1-1: USB disconnect, device number 57
Tue Jul 18 05:37:41 2023 kern.info kernel: [36386.982082] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Tue Jul 18 05:37:41 2023 kern.info kernel: [36386.990680] option 1-1:1.0: device disconnected
Tue Jul 18 05:37:41 2023 kern.info kernel: [36386.996038] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Tue Jul 18 05:37:41 2023 kern.info kernel: [36387.004579] option 1-1:1.1: device disconnected
Tue Jul 18 05:37:41 2023 kern.info kernel: [36387.048036] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Tue Jul 18 05:37:41 2023 kern.info kernel: [36387.056578] option 1-1:1.2: device disconnected
Tue Jul 18 05:37:41 2023 kern.info kernel: [36387.061933] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
Tue Jul 18 05:37:41 2023 kern.info kernel: [36387.070663] option 1-1:1.3: device disconnected
Tue Jul 18 05:37:41 2023 kern.info kernel: [36387.075850] qmi_wwan 1-1:1.4 wwan0: unregister 'qmi_wwan' usb-1b000000.usb-1, WWAN/QMI device
Tue Jul 18 05:37:43 2023 user.notice /bin/trigger_vuci_routes_reload: vuci reload_routes triggered
Tue Jul 18 05:37:45 2023 kern.info kernel: [36391.807536] usb 1-1: new high-speed USB device number 58 using ehci-platform
Tue Jul 18 05:37:46 2023 kern.info kernel: [36391.980267] option 1-1:1.0: GSM modem (1-port) converter detected
Tue Jul 18 05:37:46 2023 kern.info kernel: [36391.987063] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
Tue Jul 18 05:37:46 2023 kern.info kernel: [36391.995140] option 1-1:1.1: GSM modem (1-port) converter detected
Tue Jul 18 05:37:46 2023 kern.info kernel: [36392.001882] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
Tue Jul 18 05:37:46 2023 kern.info kernel: [36392.009937] option 1-1:1.2: GSM modem (1-port) converter detected
Tue Jul 18 05:37:46 2023 kern.info kernel: [36392.016703] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB2
Tue Jul 18 05:37:46 2023 kern.info kernel: [36392.024699] option 1-1:1.3: GSM modem (1-port) converter detected
Tue Jul 18 05:37:46 2023 kern.info kernel: [36392.031541] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB3
Tue Jul 18 05:37:46 2023 kern.info kernel: [36392.115944] qmi_wwan 1-1:1.4: cdc-wdm0: USB WDM device
Tue Jul 18 05:37:46 2023 kern.info kernel: [36392.132783] qmi_wwan 1-1:1.4 wwan0: register 'qmi_wwan' at usb-1b000000.usb-1, WWAN/QMI device, 06:8d:cf:38:ee:73
Tue Jul 18 05:37:46 2023 daemon.err mobifd: [gsm.modem0] Failed to set CNMI mode
Tue Jul 18 05:37:48 2023 daemon.info gsmd[1894]: [__new_modem:618] error: [MODEM_MANAGER] Modem `1-1 [2c7c:0306]` already exists and is registered!
Tue Jul 18 05:37:48 2023 daemon.info gsmd[1894]: [__modem_added:450] error: [MODEM_MANAGER] Unable to initialize `1-1 [2c7c:0306]` modem!
Tue Jul 18 05:37:49 2023 daemon.err mobifd: [gsm.modem0] Failed to get present service mode
Tue Jul 18 05:37:49 2023 daemon.err mobifd: [gsm.modem0] Failed to get current bands
Tue Jul 18 05:37:52 2023 daemon.err mobifd: [gsm.modem0] Init "net mode" failed. Retrying
Tue Jul 18 05:37:52 2023 daemon.err mobifd: [gsm.modem0] Failed to get present service mode
Tue Jul 18 05:37:52 2023 daemon.err mobifd: [gsm.modem0] Failed to get current bands
Tue Jul 18 05:37:54 2023 user.notice /bin/trigger_vuci_routes_reload: vuci reload_routes triggered
Tue Jul 18 05:37:55 2023 daemon.err mobifd: [gsm.modem0] Init "net mode" failed. Retrying
Tue Jul 18 05:37:55 2023 daemon.err mobifd: [gsm.modem0] Failed to get present service mode
Tue Jul 18 05:37:55 2023 daemon.err mobifd: [gsm.modem0] Failed to get current bands
Tue Jul 18 05:37:58 2023 daemon.err mobifd: [gsm.modem0] Init "net mode" failed. Retrying
Tue Jul 18 05:37:58 2023 daemon.err mobifd: [gsm.modem0] Failed to get present service mode
Tue Jul 18 05:37:58 2023 daemon.err mobifd: [gsm.modem0] Failed to get current bands
Tue Jul 18 05:38:01 2023 daemon.err mobifd: [gsm.modem0] Init "net mode" failed. Retrying
Tue Jul 18 05:38:01 2023 daemon.err mobifd: [gsm.modem0] Failed to get present service mode
Tue Jul 18 05:38:01 2023 daemon.err mobifd: [gsm.modem0] Failed to get current bands
Tue Jul 18 05:38:04 2023 daemon.err mobifd: [gsm.modem0] Init "net mode" failed. Retrying
Tue Jul 18 05:38:04 2023 daemon.err mobifd: [gsm.modem0] Failed to get present service mode
Tue Jul 18 05:38:04 2023 daemon.err mobifd: [gsm.modem0] Failed to get current bands
Tue Jul 18 05:38:07 2023 daemon.err mobifd: [gsm.modem0] Init "net mode" failed. Retrying
Tue Jul 18 05:38:07 2023 daemon.err mobifd: [gsm.modem0] Failed to get present service mode
Tue Jul 18 05:38:07 2023 daemon.err mobifd: [gsm.modem0] Failed to get current bands
Tue Jul 18 05:38:10 2023 daemon.err mobifd: [gsm.modem0] Init "net mode" failed. Retrying
Tue Jul 18 05:38:10 2023 daemon.err mobifd: [gsm.modem0] Failed to get present service mode
Tue Jul 18 05:38:10 2023 daemon.err mobifd: [gsm.modem0] Failed to get current bands
Tue Jul 18 05:38:13 2023 daemon.err mobifd: [gsm.modem0] Init "net mode" failed. Retrying
Tue Jul 18 05:38:13 2023 daemon.err mobifd: [gsm.modem0] Failed to get present service mode
Tue Jul 18 05:38:13 2023 daemon.err mobifd: [gsm.modem0] Failed to get current bands
Tue Jul 18 05:38:16 2023 daemon.err mobifd: [gsm.modem0] Init "net mode" failed. Retrying
Tue Jul 18 05:38:16 2023 daemon.err mobifd: [gsm.modem0] Failed to get present service mode
Tue Jul 18 05:38:16 2023 daemon.err mobifd: [gsm.modem0] Failed to get current bands
Tue Jul 18 05:38:19 2023 daemon.err mobifd: [gsm.modem0] Init "net mode" failed. No more retries
Tue Jul 18 05:38:20 2023 daemon.info hostapd: wlan0: STA c0:49:ef:8a:e0:28 IEEE 802.11: authenticated
Tue Jul 18 05:38:20 2023 daemon.info hostapd: wlan0: STA c0:49:ef:8a:e0:28 IEEE 802.11: associated (aid 1)
Tue Jul 18 05:38:20 2023 daemon.notice hostapd: wlan0: AP-STA-CONNECTED c0:49:ef:8a:e0:28
Tue Jul 18 05:38:20 2023 kern.notice BETTYNET: WiFi client connected: C0:49:EF:8A:E0:28
Tue Jul 18 05:38:20 2023 daemon.info hostapd: wlan0: STA c0:49:ef:8a:e0:28 RADIUS: starting accounting session C229C6FE6FCB5FE2
Tue Jul 18 05:38:20 2023 daemon.info hostapd: wlan0: STA c0:49:ef:8a:e0:28 WPA: pairwise key handshake completed (RSN)
Tue Jul 18 05:38:23 2023 daemon.info mobifd: [gsm.modem0] SMS storage: sm
Tue Jul 18 05:38:23 2023 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with 15 seconds of timeout
Tue Jul 18 05:38:23 2023 daemon.info mobifd: [gsm.modem0] Connected to operator 'Telia FI Telia'
Tue Jul 18 05:38:23 2023 daemon.err mobifd: [gsm.modem0] Failed to get serving cell info
Tue Jul 18 05:38:23 2023 daemon.info mobifd: [gsm.modem0] -CFUN- Functionality: "Full"
Tue Jul 18 05:38:23 2023 daemon.info mobifd: [gsm.modem0] -COPS- Mode: "Auto", operator: "Telia FI Telia"
Tue Jul 18 05:38:23 2023 daemon.info mobifd: [gsm.modem0] -CREG- Mode: "Enabled (with location information)", status: "Roaming", LAC: "4180", cell ID: "36241676", technology: "E-UTRAN"
Tue Jul 18 05:38:23 2023 daemon.info mobifd: [gsm.modem0] -CGREG- Mode: "Enabled (with location information)", status: "Roaming", LAC: "4180", cell ID: "36241676", technology: "E-UTRAN"
Tue Jul 18 05:38:23 2023 daemon.info mobifd: [gsm.modem0] -CEREG- Mode: "Enabled (with location information)", status: "Roaming", LAC: "4180", cell ID: "36241676", technology: "E-UTRAN"
Tue Jul 18 05:38:23 2023 daemon.info mobifd: [gsm.modem0] IP address on PDP context "1": "100.91.124.15"
Tue Jul 18 05:38:23 2023 daemon.notice netifd: Interface 'mob1s1a1' is setting up now
Tue Jul 18 05:38:23 2023 daemon.notice netifd: mob1s1a1 (4437): wwan[4437] Using wwan usb device on bus 1-1
Tue Jul 18 05:38:23 2023 daemon.notice netifd: mob1s1a1 (4437): wwan[4437] Using proto:qmi_wwan device:/dev/cdc-wdm0 iface:wwan0 desc:Quectel EG06
Tue Jul 18 05:38:24 2023 daemon.notice netifd: mob1s1a1 (4437): Using net device: wwan0
Tue Jul 18 05:38:24 2023 daemon.notice netifd: mob1s1a1 (4437): Informing driver of raw-ip for wwan0 ..
Tue Jul 18 05:38:25 2023 kern.info kernel: [36430.969771] qmi_wwan 1-1:1.4 wwan0: mode: raw IP
Tue Jul 18 05:38:25 2023 user.notice root: uqmi -d /dev/cdc-wdm0 --timeout 3000 --wda-set-data-format --link-layer-protocol raw-ip --ul-protocol disabled --dl-protocol disabled
Tue Jul 18 05:38:25 2023 daemon.notice netifd: mob1s1a1 (4437): Starting network mob1s1a1 using APN: online.telia.se
Tue Jul 18 05:38:25 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,20 --release-client-id wds --modify-profile --profile-identifier 3gpp,1 --profile-name profile1 --roaming-disallowed-flag no --auth-type none --apn online.telia.se --pdp-type ip
Tue Jul 18 05:38:26 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --get-client-id wds
Tue Jul 18 05:38:26 2023 daemon.notice netifd: mob1s1a1 (4437): 20
Tue Jul 18 05:38:26 2023 daemon.notice netifd: mob1s1a1 (4437): cid4: 20
Tue Jul 18 05:38:26 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-ip-family ipv4 --set-client-id wds,20
Tue Jul 18 05:38:26 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,20 --start-network --apn online.telia.se --profile 1 --auth-type none --username --password
Tue Jul 18 05:38:26 2023 user.notice mobile.sh: Received unknown error(1/5): "Unknown error"
Tue Jul 18 05:38:26 2023 daemon.notice netifd: mob1s1a1 (4437): pdh4: "Unknown error"
Tue Jul 18 05:38:26 2023 daemon.notice netifd: mob1s1a1 (4437): Unable to connect IPv4
Tue Jul 18 05:38:26 2023 user.notice mobile.sh: Received unknown error(5/5): "Unknown error"
Tue Jul 18 05:38:26 2023 daemon.notice netifd: mob1s1a1 (4437): Calling "mctl --reboot -i 1-1"
Tue Jul 18 05:38:26 2023 user.notice mobile.sh: Clearing uqmi processes for /dev/cdc-wdm0
Tue Jul 18 05:38:27 2023 daemon.notice netifd: mob1s1a1 (4437): Releasing client-id 20 on /dev/cdc-wdm0
Tue Jul 18 05:38:27 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,20 --release-client-id wds
Tue Jul 18 05:38:27 2023 daemon.notice netifd: mob1s1a1 (4437): Failed to create IPV4 connection
Tue Jul 18 05:38:30 2023 daemon.info mobifd: [gsm.modem0] Config reload initiated
Tue Jul 18 05:38:31 2023 daemon.info mobifd: [gsm.modem0] Initializing modem. Please wait.
Tue Jul 18 05:38:31 2023 daemon.notice netifd: mob1s1a1 (4654): Stopping network mob1s1a1
Tue Jul 18 05:38:32 2023 daemon.notice netifd: mob1s1a1 (4654): Command failed: Not found
Tue Jul 18 05:38:32 2023 daemon.notice netifd: mob1s1a1 (4654): Command failed: Permission denied
Tue Jul 18 05:38:32 2023 daemon.notice netifd: Interface 'mob1s1a1' is now down
