RUT360 Bridge/Passthrough modes do not work (Latest Firmware)
Hello, My organization has a remote site with a RUT360 acting as a 4G router. We want to deploy our own Router and security appliances, in this case Pfsense acting as a router. However, when i enable Bridge mode or Passthrough mode on the mobile network settings, the Pfsense router which ahs was set to DHCP does not receive the RUT360 public IP. I have tried factory resets, Followed the wiki articles step by step. Also to note, is when the device is set to Bridge/passthrough. I can still access the webUI as normal though its local IP - which i think is wrong?.
HJAs anyone managed to solve this issue? we are looking to remove our Teltronica devices if we cant get this resolved.
Hi BriggsyUK,
I configured Bridge Mode with latest FW version with my end device as PC. When configuring Bridge Mode, the crucial parameter here is the device MAC address. Most probably, RUT360 LAN is connected to WAN port of Pfsense. Make sure to input the WAN MAC address of Pfsense router to the configuration. You could also try to replace Pfsense to a PC as testing. Get the MAC address of Ethernet by running ipconfig /all and pull out physical address. Also, change PDP type to IPv4 (mob1s1s1 → General Settings).
Let me know if this helps.
This indeed worked, i think the difference i missed was setting the PDP to ipv4. This resolved the issue, Thank you very much.
