I am following example to test connection between the router and Azure IoT Hub.
I am following this simple example from manual RUTX Azure IoT Hub cloud connection - Teltonika Networks Wiki, though I see that the example is written for the older Firmware version.
I set up Azure IoT hub Messages Type as GSM values and follow this recommendation to test connectivity
* From router side, connect to it with CLI or SSH client and write in command **azure_iothub** and press Enter
- You should get answer that looks something like that, depending on what information you chose to send.
But getting the error
root@RUT360:~# azure_iothub
Usage: azure_iothub -n <ID> -d
If i use Device ID under -n flag like this:
root@RUT360:~# azure_iothub -n MyDeviceId
I am getting:
[Severity ] Message
[Error ] No UCI configurations parsed
[Error ] Failed to parse config
[Error ] Failed to init azure object
What is the proper way to test the connectivity?
