Hello all,
Apologies if I make some mistakes with my terminology.
I am in the unenviable position of trying to connect two networks where I have not control over the routers or addresses of the equipment.
I have a RUTX300 Router
Port 1 Wan
Port 2 Lan 1 - Network DCHP
What I have on the factory floor is two networks.
The first I have connected to Port 2 of my router it’s network range is 10.0.12.x
I have another network in 192.168.5.x range
On this second network I have a device that is trying to communicate with the address 192.168.5.100
The device it needs to read from is in Network 1 and has an IP address of 10.0.12.13
Is it possible to use a port on the router to act as 192.168.5.100 then forward all received information to 10.0.12.13
Before you ask, I don’t have control of the IP addresses assigned in either network.
Your assistance is appreciated!
