Hi.
Will the Tailscale package work on the RUT271?
I understand that tailscale on devices like RUT240 is not supported due to flash storage constraints. However the RUT271 has larger flash - twice that of the RUT240.
Thanks!
Hi.
Thanks!
The Tailscale VPN package is compatible exclusively with TRB1 (excluding TRB160), TRB5, RUTX, RUTC50 , OTD500 and RUTM series devices. This is because Tailscale demands a larger amount of flash space, which surpasses the capacity available on our other devices.
You can find more information about Tailscale here: Tailscale Configuration Example - Teltonika Networks Wiki
