RUT271 Low Voltage Shutdown
Just got a RUT271 to replace the old RUT850 in my car.
How/where can I set Shutdown Voltage for the RUT271 - eg. I’d like it to shutdown at 12,5V to ensure it is only powered when engine is running. (Like configured for my RUT850)
Thanks :crossed_fingers:
The RUT271 is not an automotive router like the RUT850, so configuring this feature requires a different approach.
For your use case, I recommend following this ignition detection configuration example: Ignition detection solution - Teltonika Networks Wiki
