RUT241 VRF package problem
Hi, Attempting to use the VRF package on an RUT241, the package installs fine and checksums match, but when trying to go to that section to configure, the page fails to load. Checking the browser console shows that the VRF.js script is being served as the incorrect MIME type:
Refused to execute script from 'http://192.168.1.1/views/network/VRF.js?v=1' because its MIME type ('text/html') is not executable, and strict MIME type checking is enabled.
Is there a workaround for this?
This issue is not intentional; the page should load normally. It appears that this problem affects all RUT241 devices. Thank you for bringing it to our attention. I have already informed our R&D team, and they will investigate the issue.
I have good news! The issue will be resolved in the upcoming major firmware release 07.08. To avoid this problem, you can downgrade to version 07.07 where VFR functions correctly. Alternatively, uninstall the current VRF packages and install this one instead —> vrf.tar.gz (18.7 KB)
Great to hear the problem has been found, thanks for looking into it so quickly!
