RUT241 VPN problem
Hello!
Still having problem with this router and VPN. Have now upgrade to firmware 7.11.3 and hope it would help, but no.
Have setup a VPN with ipsec and L2TP, and it work earlier before I upgrade the firmware to 7.11.0. If I setup a VPN from a windows10 computer, with the same information, it starts without no problem.
Has the version 7.11.x some bug inside??
Tried some more, and now the L2TP shows connected, but the IPSEC shows disconnected, and the log shows received NO_PROPOSAL_CHOSEN error notify
Any solution?? Or just wait for a new firmware, and hope it will be fixed??
I have not encountered similar issues when configuring L2TP over IPsec on the 7.11.3 firmware with a Windows 11 PC as the client. Could you verify whether the same IKE lifetimes have been set for both Phase 1 and Phase 2?
Additionally, if you haven’t already, I recommend checking our detailed L2TP over IPsec configuration example for PC in the wiki here. This guide outlines all necessary steps and common pitfalls.
If the issue persists, feel free to reach out for further troubleshooting process.
