Rut241 sms post/get
Hi
I’ve got a RUT241 that I am trying to use to send SMS alerts from using a HTTP based interface that we’ve successfully deployed before with a RUTX50 but uses the SMS gateway POST/GET functionality (Niagara4/Forest Rock TeltonikaSMS driver)
The Router is currently running 7.13.4 firmware and I cannot see anything equivalent to this POST/GET functionality within the settings? Following the below linked guide
RUT240 SMS Gateway - Teltonika Networks Wiki
Particularly confused as reviewing the spec sheets for the X50 and 240 currently, neither show “HTTP to SMS” type function? Hopefully I am missing something obvious, but failing that is there a Router that does support this currently? Or do I need to revert firmware to earlier version?
Good afternoon,
This functionality was moved to the Package manager as can be found in the firmware changelog:
Under here: RUT241 Firmware Downloads - Teltonika Networks Wiki
Simply head to System → Package manager → Search for “post” and install it.
Arturas
Thanks Arturas,
I did have a look at the package manager but only searched for “SMS” so never found the right package!
Dom
I can see that I have misunderstood your question, apologies for that.
Starting from firmware 00.07.14.0, the POST/GET services were completely withdrawn. You can find more details on this change here:
To send SMS via RUT 241 You can utilize the API requests; More information specifically on sending SMS messages can be found here: https://developers.teltonika-networks.com/reference/trb500/7.14.3/v1.6.3/messages#post-messages-actions-send
Arturas
