WiFi signal, quality and noise is always unknown on the RUT241 (tested with FW 07.06.3/6). Never had a problem with RUT240. Same issue as https://community.teltonika.lt/t/rut241-07-06-3-firmware-no-more-shows-wifi-signal
Anyone got an idea for solution?
Hi Johan,
I opened a ticket regarding the WiFi signal issue.
Teltonika has confirmed this behavior as a “bug”.
The fix is planned for version 07.07.
For a quick solution you can use the firmware 07.04.5.
This should work.
Best regards
Andreas
Unfortunately, I have the same issue with 07.04.5. Maybe because I use the global version (03).
