I already set two ports to LAN and confirmed that both of them have Internet when connecting to PCs.
But when I connect my media box to the port, the media box can show an Ethernet connection, but no Internet.
Our devices don’t come with preconfigured firewall rules that would allow only IP address access without an internet connection, especially since they both are provided to other devices on the same LAN port in your case.
I would advise checking the media box connectivity settings in this case. Additionally, is the router providing an IP address from the correct address range?
I can confirm the IP address range is correct.
The media box works well when I connect it to my home broadband network through cable.
I try to reset the RUT241, then connect the home network cable to the WAN port, and connect the media box to the LAN port. The media box can identify the Ethernet, but no data transfer.
That’s why I thought that some setting in RUT241 limits the network.
