Rut241 remote accees
Hello, i cant access the router with http, but only with https. even i have enabled both options. Why does it happen?
Hello, have you checked traffic rules in the firewall, maybe it is bugged and is not enabled? It should be called Enable_HTTP_WAN
When connecting to the remote webui, specify to which port, example: 192.168.1.1**:80**
Also which firmware version are you using?
br,
y
Yes it is enabled
i found the solution. This option was enabled and it had been blokced, but i dont know the reason.
