The RUT241 has 2 antenna connections both marked as “Mobile”. If connecting a single coax external antenna is there a connector preference, Outside connector furthermost away from WiFi or next to WiFi?
The main mobile antenna is located on the right when you’re facing the device panel with antennas attached. I’ve also marked it on the image below.
For more details about the positioning of elements on the router, you can refer to this link: RUT241 Front & Back Panels - Teltonika Networks Wiki
