i presume this is the ip address of the device connected to the RUT241 you want to reach. Use external port 9001 and internal port 9001 in your forward rule. Remember that it’s unusual for 4G providers to let you reach the RUT241 from the internet due to CGNAT (carrier grade NAT)
Take heed of @pwhooftman ‘s comment regarding CGNAT. You will need a Public IP, not ‘hiding’ behind CGNAT, to access the router and device across the internet. If you have a normal domestic SIM, then you will not be able to directly access the router or device, over the internet.
You may also want to explore our Teltonika RMS VPN Hubs or RMS Connect. These services are very easy to set up, though please note that RMS is a paid service. More information, including setup guides and resource requirements, can be found at the following links:
