RUT241 no communication to WAN port from LAN and VPN with bridge enabled
as i just talked with Support on the Phone, here the Issue i’m facing:
On a RUT241 i have devices connected to both LAN and WAN port, in settings the option ‘use WAN port as LAN’ is also enabled.
Devices on LAN and RMS VPN can’t connect to the device on WAN, ping failes and web interface won’t load, but a Ping from the Interface of the router itself is successful, further devices Downstream on the WAN port also don’t get any DHCP addresses assigned.
The Device with the IP 192.168.2.14 is on LAN, 192.168.2.15 is on WAN
Ping on the Router itself Works.
Routes for both devices (and the router itself) are set up in the VPN Hub
Regards
P. Hamel
Could you please clarify the firmware version currently running on the RUT241?
Can the device at 192.168.2.14 reach the device at 192.168.2.15 locally?
Additionally, could you provide a screenshot of the Network → VLAN → Port Based page?
Regarding the DHCP issue you mentioned, I’d like to clarify the network setup. Is the device connected directly to the WAN port, or is there a switch/router between them?
The Firmware version is RUT2M_R_00.07.21.3.
Here the VLAN Settings.
On the Router itself the LAN and WAN port connect to a SMA Data Manager M each, both have a few inverters on another network port downstream. The Data Managers have static IPs, the inverters get them assigned through DHCP, only the ones behind the Data Manager on the LAN port are listed in the DHCP Lease page on the Router.
are there any Updates on this?
Could you please clarify whether you still require assistance or if the issue has already been resolved?
By now we resolved the Issue by adding another network Switch to the setup, so no further assistance is required
