RUT241 LTE 4G Router help
Hi all,
I work for a company that provides cash out facilitates that use RUT241 LTE 4G Routers
Since late last year they’ve had constant network drop outs while processing transactions.
The modems are currently set for WAN as Primary (to use their network) and 4G/mobile signal as the back up.
I’ve been in contact with the venues IT / network department to try and resolve these issues, but I need further help to try and understand what the problem is.
I’ve downloaded the event logs and wanted to see if anyone could assist me?
As I’m a new user it won’t allow me to attach the log file
I have the log file, but can’t upload it. I did grab this from this morning. Not sure if this helps in anyway?
2439
2025-05-23 08:30:33
Switch Events
Port speed for port LAN1 changed to 100 baseT
2438
2025-05-23 08:30:33
Switch Events
Port link state of port LAN1 changed to UP
2437
2025-05-23 08:30:30
Switch Events
Port link state of port LAN1 changed to DOWN
2436
2025-05-23 08:30:19
Switch Events
Port speed for port LAN1 changed to 10 baseT
2435
2025-05-23 08:30:19
Switch Events
2434
2025-05-23 08:30:17
Switch Events
2433
2025-05-23 05:03:35
Network Operator
Connected to YES OPTUS YES OPTUS operator (internal modem)
2432
2025-05-23 05:03:35
Network Type
Joined LTE network (internal modem)
2431
2025-05-23 05:03:35
Mobile Data
Mobile data connected (internal modem)
2430
2025-05-23 05:01:53
Failover
Switched to main WAN (wan)
2429
2025-05-23 05:01:29
Switch Events
Port speed for port CPU/WiFi changed to 1000 baseT
2428
2025-05-23 05:01:29
Switch Events
Port link state of port CPU/WiFi changed to UP
2427
2025-05-23 05:01:29
Switch Events
2426
2025-05-23 05:01:29
Switch Events
2425
2025-05-23 05:01:29
Switch Events
Port speed for port WAN changed to 100 baseT
2424
2025-05-23 05:01:29
Switch Events
Port link state of port WAN changed to UP
2423
2025-05-23 05:00:44
Mobile Data
Mobile data disconnected (internal modem)
2422
2025-05-23 00:00:42
Switch Events
2421
2025-05-23 00:00:42
Switch Events
2420
2025-05-23 00:00:39
Switch Events
2419
2025-05-23 00:00:26
Switch Events
2418
2025-05-23 00:00:26
Switch Events
2417
2025-05-23 00:00:24
Switch Events
2416
2025-05-22 05:03:31
Network Operator
2415
2025-05-22 05:03:31
Network Type
2414
2025-05-22 05:03:31
Mobile Data
2413
2025-05-22 05:01:44
Failover
2412
2025-05-22 05:01:27
Switch Events
2411
2025-05-22 05:01:27
Switch Events
2410
2025-05-22 05:01:27
Switch Events
2409
2025-05-22 05:01:27
Switch Events
2408
2025-05-22 05:01:27
Switch Events
2407
2025-05-22 05:01:27
Switch Events
2406
2025-05-22 05:00:44
Mobile Data
2405
2025-05-22 00:00:39
Switch Events
2404
2025-05-22 00:00:39
Switch Events
2403
2025-05-22 00:00:35
Switch Events
2402
2025-05-22 00:00:24
Switch Events
2401
2025-05-22 00:00:24
Switch Events
2400
2025-05-22 00:00:22
Switch Events
2399
2025-05-21 05:03:40
Network Operator
2398
2025-05-21 05:03:40
Network Type
2397
2025-05-21 05:03:40
Mobile Data
2396
2025-05-21 05:01:54
Failover
2395
2025-05-21 05:01:29
Switch Events
2394
2025-05-21 05:01:29
Switch Events
2393
2025-05-21 05:01:29
Switch Events
2392
2025-05-21 05:01:29
Switch Events
2391
2025-05-21 05:01:29
Switch Events
2390
2025-05-21 05:01:29
Switch Events
I have sent you a form for private communication, please fill in the form, and in ticket ID provide this query ID which is 12813.
Arturas
