Hi, I’m running a Teltonika Router RUT241 with as SIM Card from the German Provider 1&1! In conjunction with this sim card we are facing the problem, that almost every week the router is loosing it’s internet connection via a G4 Network and due to this all communication between our vehicle charging point is terminated! In most cases even a sms reboot or status command is not recocnized at as well!
In this case I have to drive to the location of the router about 25km away and I have to execute a reboot through a direct login via the active wifi connection. After this the router starts working again!
Before initiating the reboot of the router I checked the Mobile LAN status:
The status page reported ‘connected’ and indicated a G4 network connection!
But a normal internet connection to an arbitrary website was not possible!
Before rebooting I downloaded the troubleshoot-file which I also store in the nvram of the router as well!
Attached I’ll send you the troubleshoot-file as an attachment.
Unfortunately I can’t upload the troubleshoot-file due to it is not to upload this *.tar File! Question: How can I sent you this file? Pleas let me know
Currently I’m running 10 RUT241 devices and we are facing similar problems on the other devices as well!
Please give an advice how to continue in this case. Btw. 2 weeks I had a longer telefone call with a colleague from you support and as far as I understand him, he recommended to use this channel for technical support issues of this case!
Hope to hear from you soon
Christian
