RUT241 loses connection to mobile every 2 hours
Hello, I have a problem with the RUT241.
It loses the connection to the mobile internet/LTE every 2 hours.
The latest firmware RUT2M_R_00.07.10.4 is installed.
I saw that other users in the forum also have a similar 2-hour connection problem, the “DHCP 0” entry in /etc/config/network is already there.
Is there a solution?
Peter
I apologize for any inconvenience this issue may have caused. Our developers are actively working on a resolution. In the meantime, could you please confirm whether adding the DHCP option has helped with the disconnections?
Good morning,
The problem exists even though the DHCP entry is set to 0.
I have configured an “auto reboot” but that is not a solution!
The mobile connection is lost exactly every 2 hours.
I have sent you a form to complete. Once it is filled out, I will reach out to you privately to discuss this issue further. For the ticket ID, please use “10475”.
