RUT241 eSIM reset and WAN
I have a RUT241 eSIM and I had problems with the setup. I tried resetting but there are still pending notification related to deleting the eSIM that I assume is due to not being able to setup the required internet connection.
What is the most robust way to setup internet connection such that I can release the eSIM and start over again? How do I check that I have the internet connection working properly?
Hi, you should use alternative internet source such as wired WAN or WiFi. If you select regular SIM card slot, you won’t be able to make any operations with eSIM.
Hi, thanks for responding. I have tried wired Wan, but need help how to test if the wired WAN is providing Internett access to the RUT241.
Good afternoon,
Easiest way to check whether you have an active internet connection, is to send a ping command to 8.8.8.8 or 1.1.1.1. If you go to the WEBUI System β†’ Maintenance β†’ Troubleshoot β†’ Ping . After having an alternative internet connection, you can activate your eSIM profile.
Arturas
Excellent. I will try tonight when I get home.
I have tested tonight and it is strange. When I ping 8.8.8.8 only about 1 of 5 is ok. The rest drop between 20% and 100% of the packets.
The RUT241 is connected to my router via the WAN port so it should be ok. Not sure what to do next.
In this case, I would like to recommend changin the internet wan source. Potentially try to set up a hotspot on your phone, and connect to that hotspot with our router. You can find more information how to connect here : RUT241 Wireless - Teltonika Networks Wiki in this guide. Try to test the internet connection then.
Arturas
