RUT241 eSIM – IMSI changes to 999999999999999 and network registration is denied
We are experiencing an eSIM registration issue with a Teltonika RUT241 eSIM.
Device: RUT241 eSIM
RutOS: RUT2M_R_00.07.24.5
Internal modem: SLM750-V_4.57.25_EQ101
eSIM provider: Roamic
APN: orange
Data roaming: enabled
The eSIM profile is successfully installed and is shown as Active / Enabled. SIM2 (eSIM1) is the default SIM and the ICCID is read correctly.
Initially, the eSIM successfully registered on Vodafone NL (20404) and obtained a mobile connection.
After a reconnect attempt, however, the IMSI changed to:
999999999999999
Since then, network registration fails.
A network scan detects Vodafone NL (20404), KPN NL (20408) and T-Mobile/Odido NL (20416), but they are shown as Forbidden.
We also manually selected Vodafone NL (20404). The modem detects the network with good signal (approximately -76 dBm), MCC 204 / MNC 04, but the registration result is:
Operator state: Denied
No mobile IP address is assigned.
The APN configuration has already been verified with the eSIM provider:
  • APN: orange
  • Username/password: blank
  • Authentication: None
  • Data roaming: enabled
We have also verified that there are no pending eSIM notifications.
The RUT241 troubleshoot logs contain repeated messages including:
GSM error in "mb_set_net_reg" (Failed to parse response)
The modem was also reported as not responsive once and RutOS automatically restarted it.
The current situation is therefore:
eSIM Active/Enabled → ICCID readable → IMSI 999999999999999 → network visible → registration DENIED → packet service detached
Could Teltonika please advise what 999999999999999 as IMSI indicates on the RUT241/SLM750 and whether this points to an eSIM/modem issue?
Is there a modem reset, modem firmware procedure or AT-command diagnostic that we should perform?
We have a complete Troubleshoot file available, but have not attached it publicly because it contains device/configuration information. We can provide it privately to Teltonika support if required.
We do not want to delete or reinstall the current eSIM profile unless Teltonika confirms this is safe.
Thank you.
Hello @KindZephyr52,
Thank you for reaching out to us and for providing such a detailed description of the issue.
We have forwarded the issue to our R&D team for further investigation. Once we receive any troubleshooting suggestions or if we require any additional or sensitive information from your end, we will let you know as soon as possible.
We appreciate your patience and cooperation while we investigate this matter.
P.
For troubleshooting purposes, could you please access the device’s CLI either through the WebUI or via SSH and provide us with the output of the following command:
gsmctl -y
This command will display the exact firmware version of the device’s modem, which will help us investigate the issue further.
For more information on how to access the devices CLI, please refer to the following link:
We look forward to your response.
P.
With an rutx50 esim device we had exactly the same thing twice. IMSI changed to 999999999999999 after a reconnect. Only a new esim fixed it.
I experienced the exact same behaviour as the topic starter with a RUTX14 using a 9esim v3 card. I am also using a Roamic esim. The connection starts up fine but after 30s - 1min there is a disconnect and the then the connection I see an IMSI 999999999999999 and the connection is denied.
How to troubleshoot this further? (I have the latest GSM firmware EG12EAPAR01A15M4G_01.202.01.202 on my device)
Hello @Cemildegirmenci and @ArdK,
Glad to hear that using a new eSIM profile helped resolve the issue, @Cemildegirmenci. Could you also please confirm whether the issue has remained resolved and has not occurred again since?
@ArdK, the issue you are experiencing may be different from the one originally reported in this thread. To better understand the situation and assist you with further troubleshooting, we will need some potentially sensitive information, such as the device’s Troubleshoot file. These files may contain sensitive data, including passwords, public IP addresses, serial numbers, and other device-related information.
To avoid sharing this information publicly, we have sent you a form to complete. You should receive it at the email address associated with your Community Forum account.
When completing the form, please enter 21301 in the Ticket ID field so we can associate the submitted information with this forum thread.
Once you have submitted the form, we will continue the communication through a private channel.
Thank you for your patience and cooperation
P.
With a new esim it also appeared again. This was only with Georgien esim from megaesim, with other esims it never happened
Cemil
Thanks for the reply. I filled in the form you sent. I did not get a confirmation (yet) so please feel free to contact me via e-mail if you need more information.
Hello @ArdK
Thank you for filling out the form.
We have sent you further instructions regarding your issue via private channel.
P.
