RUT241 ESIM Enablement
I need to enable an eSIM on my RUT241 eSIM router recently purchased. The instructions about the need for internet access are not clear. I have an iPhone that has with hotspot enabled and would like to use this. What are the steps to enable this as a WAN on the router please? There is talk of enabling interfaces but cannot see this on my menu choices.
BOOMEL
Hi…
About using your iPhone as hotspot and make the RUT241 connect to it
Please… take a look at:
https://wiki.teltonika-networks.com/view/RUTOS_relay_/_Wi-Fi_extender_/_repeater_/_bridge_configuration
RUT241 client mode
https://wiki.teltonika-networks.com/view/RUT241_Wireless#Client_Mode
and
doing a WiFi wan
The following url is about how to activate your eSim…
To do this procecure, please… update your router and keep it connected to internet (rj45 wan or WiFi wan)
https://wiki.teltonika-networks.com/view/Template:Networking_rutos_manual_esim
To update the rut241, you can download the firmware at this url
https://wiki.teltonika-networks.com/view/RUT241_Firmware_Downloads
Thank you I think I have got most of that. However the video does not refer to the RUT241 eSIM and there is no menu item network and then interfaces. This is the bit that confuses me. How do I make the hotspot connection to my iphone as the WAN?
Thanks.
BOOMEL
IPhone WiFi Hotspot
Google it…
iPhone hotspot mode, also known as Personal Hotspot, allows users to share their iPhone’s cellular data connection with other devices. This mode is useful when there is no Wi-Fi network available.
How to set up Personal Hotspot
  1. Go to Settings
  2. Select Personal Hotspot
  3. Turn on Allow Others to Join
  4. Optionally, change the Wi-Fi password
How to connect a device to Personal Hotspot
  1. On the device you want to connect, turn on Personal Hotspot
  2. Open the Wi-Fi menu
  3. Select the iPhone’s name
  4. Enter the password
When to use Personal Hotspot
Personal Hotspot is best for emergency or incidental use because the cellular data connection speed may be slower than public Wi-Fi. It may also drain the iPhone’s battery quickly.
Also… from Apple support page
Marcelo,
Apologies I am not making myself clear. The iPhone setup is no issue. I have also followed the instruction re setting up the WiFi ssid as per the video. In the video about 2/3rds the way long, there is reference to network->interface and putting the new ssid as per the enclosed screenshot (first image). I do not have this menu option on my menu as per the enclosed comparison screenshot (second image). I have the latest firmware on my router.
BOOMEL
I can see other connection just can’t use it.
Hi…
Please… look at the top of dashboard…
Are you using BASIC or ADVANCED?
Advanced this has been set from the start. I have also just upgraded to the latest firmware
AND under WiFi
Your device, don’t have the " scan 2.4GHz " option at right?
NoI have managed to scan the 2.4ghz and connect as per screenshot above as a client
i am trying to download esim profile but get enclosed error. i am assuming this is because there is no internet to download. i have tried manual and qr code
Also I am unable to see iphone connection is there a way to connect hidden SSID
I have sent you a form to fill out. Once completed, I will contact you privately regarding this issue.
Please use “12121” as the ticket ID.
