RUT241 downgrade bootloader page not found
Openvpn stopped working after update to RUT2M_R_00.07.09.1_WEBUI.
After downgrade to 00.07.08.2 passwords are not valid anymore(admin01 or the one i setup).
Bootloader is not working.
It is a new device.
Is there a solution or do i have to send it in?
Regards
I did try firmware reset and now bootloader is working as expected.
Could you please provide more information regarding the OpenVPN issue that occurred after the firmware update? Were there any logs or errors related to the OpenVPN connection?
Can you try upgrading to firmware version 9.03 (which can be downloaded here: RUT241 Firmware Downloads) and check if the issue persists? If it does, I will send you a form so I can contact you privately regarding the troubleshoot file.
Hi Marija,
i think it was totaly my fault if you look at the address i have entered to access the bootloader.
Regarding the openvpn issue, i’m currently testing. It maybe possible that we have faulty sim cards.
Someone from teltonika contacted my already to assist/solve the vpn issue.
Bastian
Thank you for the information. Please let me know if you need any additional help regarding this topic!
