RUT241 and RUT240 Internal modem firmware update
Some time ago I contacted you because I had some problems with my devices (RUR240 and RUT241).
After some emails, we came to the conclusion that it was necessary to update the internal modem firmware. For this you recommended me to “Connect your RUT241 to a different WAN source (such as cable or Wi-Fi) and configure it as primary WAN source”. Then, in the next email you explained to me that “we do not recommend upgrading the internal modem firmware if the device does not have an alternative WAN source besides the mobile one, as there is a risk of damaging the modem during the upgrade process”.
My question is: If I connect the RUT241 to a hotspot from the mobile for the upgrade, will it be safe enough, or do you recommend just the WAN cable connection?
Thank you very much.
Yes, you can use WiFi for modem update too. The only thing is needed that your mobile hotspot connection to be good, so that new modem update files could be downloaded.
Hello @ppi,
Could you please confirm whether your issue has been resolved or if you still require any assistance?
