RUT240 wireless station mode: cannot add more than 1?
Hi, I was able to configured RUT240 primary WAN using WIFI, after scanning I picked an AP from a list and connected to the internet. But I would like to know how to have RUT240 check for multiple AP to connect to, and it seems the “add” button is greyed out in the “wireless configuration” page?
Thanks in advance.
I think you need to update to 7.6 version. This is legacy firmware which might not have this function.
Thank you for the reply. I have since updated to 07.06.15, and I understand that it is now called “multi AP” mode…but I found that the connection is not stable compare to a single AP under “client” mode. (also I found the name confusing. you have AP mode where you are the AP, but in multi AP mode you are actually the client)
