RUT240 WebUI "Failed to load menu data"
I just updated the firmware of my RUT240 router because the web interface was stuck on the “loading” message.
After several attempts, I managed to get the router to start correctly with the firmware RUT2_R_00.07.04.1_WEBUI.bin. However, when I tried to enter through the WebUI I got the following message: Failed to load menu data. Since this case is similar to the one reported in ticket 10072, I connected to the router via ssh and executed the following command: hexdump -C /dev/mtd1. As a result, I got only f as shown below:
root@Teltonika-UNKNOW:~# hexdump -C /dev/mtd1
00000000 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................|
00010000
I would appreciate if you could help me to solve this problem.
Best regards
To help resolve your issue we’ll need to arrange a remote session, I have sent you a form to fill out. When completing the form, please use 12076 as the ticket ID. Once submitted, we will contact you privately with further assistance.
Hello, I have the same problem. How was it solved?
Hello @Jens1111,
As mentioned, to resolve this issue, we’ll need to arrange a remote session. I have sent you a form to fill out. When completing the form, please use 12076-2 as the ticket ID. Once submitted, we will contact you privately with further assistance.
okay, thanks. where did you send the form? I can’t find it.
The form should have been sent to your email (the one used to register on the forum). Please check your inbox as well as your spam/junk folder, in case it was filtered there.
For this matter, I have sent you a form to fill out. When completing the form, please use 12076-3 as the ticket ID. Once submitted, we will contact you privately with further assistance.
