RUT240 - unable to detect modem
HI,
My RUT240 can’t detect the Internal Modem - CLI reports :slight_smile:
 Teltonika RUT2 series 2025
Device: RUT240
Kernel: 5.4.291
Firmware: RUT2_R_00.07.06.18
Build: ce8057a9b2c
Build date: 2025-04-08 06:26:53
root@RUT240:~# lsusb
Bus 001 Device 001: ID 1d6b:0002
I’ve re-flashed via Ethenet and Factory Reset it.
please advise what else I can try?
Thank you
Iain
Thank you for reaching out. To assist you effectively, we’ll need to continue this process privately. You should find a support request form in the inbox of the email address you used for your forum registration. Kindly fill out the form, and please reference Ticket ID: 14182 when submitting it. Once the form is completed, we’ll contact you directly via email to investigate the issue in detail and help work towards a solution.
