After the latest update to version RUT2_R_00.07.06.16, the SMS options sshon
and sshoff
are no longer functioning. This is a significant issue for us, as we rely on sshon
to enable remote SSH access for firmware updates on multiple RUT240 devices. Unfortunately, after completing the updates, sshoff
does not work to disable remote SSH access.
Ok so I managed to use the UCI api SMS commands successfully instead.
Disable remote SSH with this SMS command:
Password uci set dropbear.@dropbear[0]._sshWanAccess=0
Is the sshon
and sshoff
the only SMS functionality not working, or have you tested other SMS utilities that are also not functioning?
Hi Marija,
Did you see my second message? I mention that I got a UCI command working via SMS.
Also to note I see in SMS commands on that latest update that there is only a SSH option, no sshon
and sshoff
, were these options removed?
I apologize for any confusion. Regarding the issue, I have just tested sshoff
and sshon
on my device running firmware version 07.06.16, and everything is working correctly. I would like to review your troubleshoot file to check for any potential issues.
I have sent you a form to fill out, and once completed, I will contact you privately. Please use the ticket ID “9334”.
