RUT240 Periodic Reboots
Firmware: RUT2XX_R_00.01.14.1
Hi we have one particular RUT240 that after a daily periodic reboot at 03:00 am it then does a periodic reboot (log entry) approximately every 3 minutes for another 3 times (so it logs 4 period reboot each day). We have many other units on the same firmware.
Do you have any insights into why this may be happening?
regards
Ian
Good afternoon,
Due to the firmware you are running, the most likely reason is going to be that.
Please upgrade the firmware, ideally via the bootloader method. Reconfigure the device up to your specifications. If you are not setting any scheduled reboot tasks, or don’t have any scripts running, the device should not be periodically rebooting.
Reset instructions : RUT240 Device Recovery Options - Teltonika Networks Wiki
Newest firmware : RUT240 Firmware Downloads - Teltonika Networks Wiki
Arturas
