HI,
i want to send Binary sms via teltonika router.
Trying to do this via SSH:
gsmctl -A AT+CMGF=0
After command gsmctl -A AT+CMGS=19 i get timeout. what could be issues?
HI,
gsmctl -A AT+CMGF=0
You can’t achieve it with gsmctl because it provides only minimal functionality for interacting with the modem. However, you can accomplish it via SSH by following these steps:
This is how you can send messages via SSH using AT commands. However, please note that when you execute the “/etc/init.d/gsmd stop” command, your modem will become unreachable. To restore accessibility, you will need to run the command “/etc/init.d/gsmd start”.
If there’s anything else you need help with, please feel free to ask.
Hi Marija,
thank you for replay, after entering commands i receive constant ping:
+QCSQ: “LTE”,-64,-98,116,-14
+QCSQ: “LTE”,-64,-98,112,-14
+QCSQ: “LTE”,-64,-98,109,-14
+QCSQ: “LTE”,-70,-98,104,-14
+QCSQ: “LTE”,-70,-98,108,-14
+QCSQ: “LTE”,-70,-98,106,-14
+QCSQ: “LTE”,-70,-98,109,-14
is there a way to stop this?
If you wish to stop the outputs, you can enter the “AT+QCSQ=0” command. This command will stop the messages from the device for a while until you restart it, giving you a break from the constant stream of responses.
Please inform me if you require assistance with anything else.
Best Regards
