RUT240 Modbus client option "Store on change only"
Hello, I’m using RUT240, RUT241 and RUT 956. I’ve seen that, on RUT240 only, it is NOT available the option “store on data change only” in “modbus tcp client”. Will it be implemented? it would be useful to be able to send data via mqtt only when necessary, saving a lot of useless sendings. Thank you
The Store on change feature was added with the firmware version 7.13, as seen in the changelogs of each firmware version: RUT241 Firmware Downloads - Teltonika Networks Wiki
As the RUT240 is an EOL (End-of-Life) device, the only firmware updates it’ll receive are ones with security changes/improvements only; no new functionalities will be added. The latest version for the RUT240 is 7.06.18.
