we updated a RUT240 to firmware 07.06.19.
Since then, the 2 devices on eth0 and eth1 cannot communicate with each other anymore.
It seems the bridge does not work correctly.
I tried removing and re-setting the bridge, even delete and setup the lan interface from scratch.
Below you find ping and ifconfig output:
10.11.63.10 is on eth0 and 10.11.63.100 is on eth1.
I want to point out that there is no packets logged on eth1 even though the ping went through.
Any suggestions?
Torsten
root@SIS-BIE2:~# ping 10.11.63.10PING 10.11.63.10 (10.11.63.10): 56 data bytes64 bytes from 10.11.63.10: seq=0 ttl=64 time=0.728 ms64 bytes from 10.11.63.10: seq=1 ttl=64 time=0.747 ms64 bytes from 10.11.63.10: seq=2 ttl=64 time=0.807 ms64 bytes from 10.11.63.10: seq=3 ttl=64 time=0.735 ms^C— 10.11.63.10 ping statistics —4 packets transmitted, 4 packets received, 0% packet lossround-trip min/avg/max = 0.728/0.754/0.807 msroot@SIS-BIE2:~# ping 10.11.63.100PING 10.11.63.100 (10.11.63.100): 56 data bytes64 bytes from 10.11.63.100: seq=0 ttl=64 time=0.907 ms64 bytes from 10.11.63.100: seq=1 ttl=64 time=0.812 ms64 bytes from 10.11.63.100: seq=2 ttl=64 time=0.799 ms64 bytes from 10.11.63.100: seq=3 ttl=64 time=0.827 ms^C— 10.11.63.100 ping statistics —4 packets transmitted, 4 packets received, 0% packet lossround-trip min/avg/max = 0.799/0.836/0.907 msroot@SIS-BIE2:~# ipconfig-ash: ipconfig: not foundroot@SIS-BIE2:~# ifconfigbr-ifLan1 Link encap:Ethernet HWaddr 00:1E:42:19:05:FCinet addr:10.11.63.1 Bcast:10.11.63.255 Mask:255.255.255.0inet6 addr: fe80::21e:42ff:fe19:5fc/64 Scope:LinkUP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1RX packets:87 errors:0 dropped:0 overruns:0 frame:0TX packets:107 errors:0 dropped:0 overruns:0 carrier:0collisions:0 txqueuelen:1000RX bytes:8348 (8.1 KiB) TX bytes:12227 (11.9 KiB)
eth0 Link encap:Ethernet HWaddr 00:1E:42:19:05:FCUP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1RX packets:87 errors:0 dropped:0 overruns:0 frame:0TX packets:107 errors:0 dropped:0 overruns:0 carrier:0collisions:0 txqueuelen:1000RX bytes:9566 (9.3 KiB) TX bytes:12227 (11.9 KiB)Interrupt:5
eth1 Link encap:Ethernet HWaddr 00:1E:42:19:05:FDUP BROADCAST MULTICAST MTU:1500 Metric:1RX packets:0 errors:0 dropped:0 overruns:0 frame:0TX packets:0 errors:0 dropped:0 overruns:0 carrier:0collisions:0 txqueuelen:1000RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)Interrupt:4
lo Link encap:Local Loopbackinet addr:127.0.0.1 Mask:255.0.0.0inet6 addr: ::1/128 Scope:HostUP LOOPBACK RUNNING MTU:65536 Metric:1RX packets:25 errors:0 dropped:0 overruns:0 frame:0TX packets:25 errors:0 dropped:0 overruns:0 carrier:0collisions:0 txqueuelen:1000RX bytes:2959 (2.8 KiB) TX bytes:2959 (2.8 KiB)
qmimux0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00inet addr:10.142.149.115 P-t-P:10.142.149.115 Mask:255.255.255.255inet6 addr: fe80::df1d:b82a:bb6e:70c6/64 Scope:LinkUP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1RX packets:2012 errors:0 dropped:0 overruns:0 frame:0TX packets:2146 errors:0 dropped:0 overruns:0 carrier:0collisions:0 txqueuelen:1000RX bytes:281438 (274.8 KiB) TX bytes:669298 (653.6 KiB)
tun_c_enscloud Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00inet addr:10.1.7.226 P-t-P:10.1.7.226 Mask:255.255.255.240inet6 addr: fd:0:0:817e::2/64 Scope:Globalinet6 addr: fe80::75ab:8d71:4b0b:a133/64 Scope:LinkUP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1RX packets:1956 errors:0 dropped:0 overruns:0 frame:0TX packets:2078 errors:0 dropped:0 overruns:0 carrier:0collisions:0 txqueuelen:500RX bytes:164593 (160.7 KiB) TX bytes:474423 (463.3 KiB)
wwan0 Link encap:Ethernet HWaddr 02:A2:B9:54:FE:C3inet6 addr: fe80::a2:b9ff:fe54:fec3/64 Scope:LinkUP BROADCAST RUNNING MULTICAST MTU:4096 Metric:1RX packets:1773 errors:0 dropped:1773 overruns:0 frame:0TX packets:1675 errors:0 dropped:0 overruns:0 carrier:0collisions:0 txqueuelen:1000RX bytes:272110 (265.7 KiB) TX bytes:603448 (589.3 KiB)
root@SIS-BIE2:~#
