Такой вопрос, где посмотреть публичный IP адрес роутера? Нигде не могу найти.
To view the current WAN IP address of your device, head to your WebUI (usually it’s under 192.168.1.1) → Login → Press Network → WAN and you will see your interfaces, which one of them will have an IP address (for example, if you’re using a mobile connection, mob1s1a1 or mob1s2a2 will have an IP). Alternatively, you can access your device’s SSH/CLI and enter the command ifconfig to see the IP addresses of your interfaces.
Now to differentiate between the two, you can follow this guide explaining the difference between a Private and Public IP address: Private and Public IP Addresses - Teltonika Networks Wiki
да пишется айпи, но почему то написано Частный IP, почему так может быть? и как это решается?
To narrow down the reason as to why you’re receiving a private IP address, I need to review the logs that could contain sensitive information, so to avoid leaking this sensitive information, I’ve sent you a form to fill out. In the Ticket ID field, simply enter 14564 and I’ll reach out to you privately.
