Is it possible to do a deeper reset to default?
I tried with the reset button (even for 20 seconds). I have the three lights flashing but I can’t connect to 192.168.1.1 or even ping it.
The LAN LED flashes but there is no communication.
I also tried putting the PC in DHCP but I am not assigned an IP.
At the bottom of the page - Bootloader Recovery.
Can you try that?
As TeWe_B mentioned, please try accessing the bootloader menu (it is a special router state used as a recovery tool in case the router becomes inaccessible even after a factory reset). If that doesn’t resolve the issue, please let me know so I can assist you further.
Perfect, I solved it.
I have another problem.
On RUT241 I have an IPsec VPN connected successfully.
A Codesys UDP communication passes over this VPN using ports 1740-1743.
I added a firewall traffic rules but the communication doesn’t work
If I use Modbus TCP IP on port 502 the communication works.
How should I set the rule?
Thank you. Luca
