RUT240 - Firmware RUT2_R_00.07.06
Hello community,
I have configured my RUT240 to connect to a wireguard server. The handshake is working.
Similar to my other openwrt setups, I want to use vpn-policy-routing to route the LAN port via the wireguard tunnel. The problem is that I can’t seem to find the necessary package.
opkg update
opkg install vpn-policy-routing
results in:
Unknown package ‘vpn-policy-routing’.
So I assume that there is no support and it might not work with RUT240?
In the web UI of the RUT240 I found an entry “Policy based routing” (https:///network/routes/advanced_routing), but I don’t know what to enter here. Any help would be great.
f1r3
A similar issue has been addressed in this thread, just replace vsftpd by vpn-policy-routing.
Thanks for the reply. I’m going to try that later.
