RUT240 Cannot use wan port as LAN
Hello
I follow method on this page but still cannot use wan as lan
https://wiki.teltonika-networks.com/view/Setting_up_WAN_as_LAN
Wan port led not blink too
Lan port can use normally
Apologies for the late reply.
Could you please explain how you are testing this? What device is connected to the second port that you are trying to use as a WAN port?
When you enable ‘WAN port as LAN’, and then connect the ethernet cable from the PC to your RUT240, are you able to access the WebUI via its LAN IP address?
i test by use the same cable connect from my computer to lan it can access to webui and receive DHCP
but if i chang to wan it cannot access to webui and didn’t receive DHCP
You mention ‘if i chang to wan it cannot access to webui’.
Could you please clarify if you want to configure your WAN port as a LAN port, or you want to configure your LAN port as a WAN port?
If you are looking to configure LAN port as a WAN port, there is a separate wiki page for that here.
