RUT240 Bridge mode
I have a RUT240 in bridge mode successfully connected via SIM card.
I have enabled bridge mode but the IP address is not being served back to the connected host. Same thing with passthrough mode.
The config is essentially a default config with bridge mode turned on and the mac address of the remote NIC added. Still DHCP hangs and never gets an address.
I haven’t got any errors in the event log. Is there anything further that needs to be configured to enable this feature?
note: I am using the latest legacy firmware.
No additional configuration should be required for the bridge or passthrough mode to function beyond what you have already listed.
Could you please try upgrading to the latest (non-legacy) firmware to check whether the issue still persists?
You can download it here: RUT240 Firmware Downloads - Teltonika Networks Wiki
