Hi!
I generated new certificates with EasyRSA3 for OpenVPN clients.
I tested OpenVPN client configs on computer and they are ok.
Then I load OpenVPN client configs to RUT200 or RUT240 routers,
routers stop answer to ping and WebUI, only way to get routers alive is reset to
factory defaults.
EASYRSA_ALGO ec
EASYRSA_CURVE secp384r1
Is this too much for old RUT2x routers or can someone give me explanation why this happening.
br,
Tarts
I want to inform you that certificates can be generated directly via the WebUI by navigating to System → Administration → Certificates. In the Certificate Manager section, you can view all generated certificates and download them. This method is quick and straightforward for generating certificates.
However, as I understand, you have been generating certificates via your PC following the instructions provided here: How to generate TLS certificates (Windows). If you wish to continue generating certificates using your PC, please let me know.
