RUT240 and relayd with multiAP
We are using a RUT240 router. Router is connnected with a Ruckus AP.
With RelaydPackige the device behind router can be reached from our wifinetwork.
This setup works fine.
Is it correct that if RUT 240 is connected to a multiAP (from Ruckus) network, RelayD is not available?
What is best setup to reach this?
Laurens Bol
I´m facing the same problem!
When using RelayD I can´t use MultiAP.
What might be the solution for this?
I must use MultiAP, because it has to work
in a warehouse with several accesspoints.
Best regards
Andreas
