I have a strange situation with RMS that is happening on 2 RUT230 devices with firmware RUT2_R_00.07.03.4 (last for this model).
Those devices where previously used only with RMS remote management, but have been recently modified to also connect to an RMS VPN hub (each one to a different hub).
All works as expected for a while, but many times at day, RUT230 disconnects from the VPN hub, even if it remain reachable from remote management. I’m sure that there is no connectivity issue during this disconnection.
I’ve replicated the same problem using another RUT230 on a different location and internet connection, with all parameters at factory default except for settings needed for internet access and RMS, so i’ve excluded that the issue is caused by some misconfiguration on the router itself.
When this issue happens, the only way to make the RUT230 come back in the VPN in a short time is to use the RMS VPN HUB button to update configuration and certificated on the device, this way in less than a minute it comes back in the VPN.
It comes back even if we do nothing, but it can take anywhere between a few minutes minutes and 3-4 hours to come back.
In System log there is a clear pattern, a while after the “Initialization Sequence Completed” openvpn log, there is a “Inactivity timeout (–ping-restart), restarting”, followed by a dnsmasq restart. After that, there is a variable number of log blocks like the one below, after a variable number of this “blocks” (can be a few or hundreds) it finally comes back online, with a new “Initialization Sequence Completed” message and a new dnsmasq restart.
: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
: TCP/UDP: Preserving recently used remote address: [AF_INET]3.69.106.81:41691
: UDP link local: (not bound)
: UDP link remote: [AF_INET]3.69.106.81:41691
: [UNDEF] Inactivity timeout (–ping-restart), restarting
: SIGUSR1[soft,ping-restart] received, process restarting
This below is a portion of the system log from the RUT230 in my netwotk where i’ve been able to replicate the issue. In this case the disconnection is of less than 10 minutes, with less than 30 connection attempts before reconnection, but as stated above, in other cases the same issue have been around for hours with hundreds of failed connection attempts.
Extract from System Log
Fri Oct 10 08:49:47 2025 daemon.warn wpa_supplicant[3200]: wlan0: Undefined secondary channel: drop OBSS scan results
Fri Oct 10 08:52:47 2025 daemon.warn wpa_supplicant[3200]: wlan0: Undefined secondary channel: drop OBSS scan results
Fri Oct 10 08:55:47 2025 daemon.warn wpa_supplicant[3200]: wlan0: Undefined secondary channel: drop OBSS scan results
Fri Oct 10 08:58:47 2025 daemon.warn wpa_supplicant[3200]: wlan0: Undefined secondary channel: drop OBSS scan results
Fri Oct 10 09:01:47 2025 daemon.warn wpa_supplicant[3200]: wlan0: Undefined secondary channel: drop OBSS scan results
Fri Oct 10 09:03:18 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: [teltonika-vpn-kZEnC567luRo2nKC] Inactivity timeout (–ping-restart), restarting
Fri Oct 10 09:03:18 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: net_addr_ptp_v4_del: 192.168.255.10 dev tun_c_rms_kZEnC
Fri Oct 10 09:03:18 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: /etc/openvpn/updown.sh tun_c_rms_kZEnC 1500 1553 192.168.255.10 192.168.255.9 init
Fri Oct 10 09:03:18 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: SIGUSR1[soft,ping-restart] received, process restarting
Fri Oct 10 09:03:22 2025 daemon.info dnsmasq[5716]: exiting on receipt of SIGTERM
Fri Oct 10 09:03:22 2025 daemon.info dnsmasq[16637]: Connected to system UBus
Fri Oct 10 09:03:22 2025 daemon.info dnsmasq[16637]: started, version 2.85 cachesize 150
Fri Oct 10 09:03:22 2025 daemon.info dnsmasq[16637]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Fri Oct 10 09:03:22 2025 daemon.info dnsmasq[16637]: UBus support enabled: connected to system bus
Fri Oct 10 09:03:22 2025 daemon.info dnsmasq-dhcp[16637]: DHCP, IP range 192.168.10.100 – 192.168.10.249, lease time 12h
Fri Oct 10 09:03:22 2025 daemon.info dnsmasq[16637]: using only locally-known addresses for domain test
Fri Oct 10 09:03:22 2025 daemon.info dnsmasq[16637]: using only locally-known addresses for domain onion
Fri Oct 10 09:03:22 2025 daemon.info dnsmasq[16637]: using only locally-known addresses for domain localhost
Fri Oct 10 09:03:22 2025 daemon.info dnsmasq[16637]: using only locally-known addresses for domain invalid
Fri Oct 10 09:03:22 2025 daemon.info dnsmasq[16637]: using only locally-known addresses for domain bind
Fri Oct 10 09:03:22 2025 daemon.info dnsmasq[16637]: using nameserver 8.8.4.4#53
Fri Oct 10 09:03:22 2025 daemon.info dnsmasq[16637]: using nameserver 8.8.8.8#53
Fri Oct 10 09:03:22 2025 daemon.info dnsmasq[16637]: using only locally-known addresses for domain lan
Fri Oct 10 09:03:22 2025 daemon.info dnsmasq[16637]: reading /tmp/resolv.conf.d/resolv.conf.auto
Fri Oct 10 09:03:22 2025 daemon.info dnsmasq[16637]: using nameserver 192.168.1.1#53
Fri Oct 10 09:03:22 2025 daemon.info dnsmasq[16637]: read /etc/hosts - 4 addresses
Fri Oct 10 09:03:22 2025 daemon.info dnsmasq[16637]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Fri Oct 10 09:03:22 2025 daemon.info dnsmasq-dhcp[16637]: read /etc/ethers - 0 addresses
Fri Oct 10 09:03:23 2025 daemon.warn openvpn(rms_kZEnC567luRo2nKC)[18631]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Oct 10 09:03:23 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: TCP/UDP: Preserving recently used remote address: [AF_INET]3.69.106.81:41691
Fri Oct 10 09:03:23 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link local: (not bound)
Fri Oct 10 09:03:23 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link remote: [AF_INET]3.69.106.81:41691
Fri Oct 10 09:03:38 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: [UNDEF] Inactivity timeout (–ping-restart), restarting
Fri Oct 10 09:03:38 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: SIGUSR1[soft,ping-restart] received, process restarting
Fri Oct 10 09:03:43 2025 daemon.warn openvpn(rms_kZEnC567luRo2nKC)[18631]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Oct 10 09:03:43 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: TCP/UDP: Preserving recently used remote address: [AF_INET]3.65.167.143:41691
Fri Oct 10 09:03:43 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link local: (not bound)
Fri Oct 10 09:03:43 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link remote: [AF_INET]3.65.167.143:41691
Fri Oct 10 09:03:58 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: [UNDEF] Inactivity timeout (–ping-restart), restarting
Fri Oct 10 09:03:58 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: SIGUSR1[soft,ping-restart] received, process restarting
Fri Oct 10 09:04:03 2025 daemon.warn openvpn(rms_kZEnC567luRo2nKC)[18631]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Oct 10 09:04:03 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: TCP/UDP: Preserving recently used remote address: [AF_INET]3.69.106.81:41691
Fri Oct 10 09:04:03 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link local: (not bound)
Fri Oct 10 09:04:03 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link remote: [AF_INET]3.69.106.81:41691
Fri Oct 10 09:04:18 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: [UNDEF] Inactivity timeout (–ping-restart), restarting
Fri Oct 10 09:04:18 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: SIGUSR1[soft,ping-restart] received, process restarting
Fri Oct 10 09:04:23 2025 daemon.warn openvpn(rms_kZEnC567luRo2nKC)[18631]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Oct 10 09:04:23 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: TCP/UDP: Preserving recently used remote address: [AF_INET]3.65.167.143:41691
Fri Oct 10 09:04:23 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link local: (not bound)
Fri Oct 10 09:04:23 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link remote: [AF_INET]3.65.167.143:41691
Fri Oct 10 09:04:38 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: [UNDEF] Inactivity timeout (–ping-restart), restarting
Fri Oct 10 09:04:38 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: SIGUSR1[soft,ping-restart] received, process restarting
Fri Oct 10 09:04:43 2025 daemon.warn openvpn(rms_kZEnC567luRo2nKC)[18631]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Oct 10 09:04:43 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: TCP/UDP: Preserving recently used remote address: [AF_INET]3.69.106.81:41691
Fri Oct 10 09:04:43 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link local: (not bound)
Fri Oct 10 09:04:43 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link remote: [AF_INET]3.69.106.81:41691
Fri Oct 10 09:04:48 2025 daemon.warn wpa_supplicant[3200]: wlan0: Undefined secondary channel: drop OBSS scan results
Fri Oct 10 09:04:59 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: [UNDEF] Inactivity timeout (–ping-restart), restarting
Fri Oct 10 09:04:59 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: SIGUSR1[soft,ping-restart] received, process restarting
Fri Oct 10 09:05:04 2025 daemon.warn openvpn(rms_kZEnC567luRo2nKC)[18631]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Oct 10 09:05:04 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: TCP/UDP: Preserving recently used remote address: [AF_INET]3.65.167.143:41691
Fri Oct 10 09:05:04 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link local: (not bound)
Fri Oct 10 09:05:04 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link remote: [AF_INET]3.65.167.143:41691
Fri Oct 10 09:05:19 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: [UNDEF] Inactivity timeout (–ping-restart), restarting
Fri Oct 10 09:05:19 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: SIGUSR1[soft,ping-restart] received, process restarting
Fri Oct 10 09:05:24 2025 daemon.warn openvpn(rms_kZEnC567luRo2nKC)[18631]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Oct 10 09:05:24 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: TCP/UDP: Preserving recently used remote address: [AF_INET]3.69.106.81:41691
Fri Oct 10 09:05:24 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link local: (not bound)
Fri Oct 10 09:05:24 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link remote: [AF_INET]3.69.106.81:41691
Fri Oct 10 09:05:39 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: [UNDEF] Inactivity timeout (–ping-restart), restarting
Fri Oct 10 09:05:39 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: SIGUSR1[soft,ping-restart] received, process restarting
Fri Oct 10 09:05:44 2025 daemon.warn openvpn(rms_kZEnC567luRo2nKC)[18631]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Oct 10 09:05:44 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: TCP/UDP: Preserving recently used remote address: [AF_INET]3.65.167.143:41691
Fri Oct 10 09:05:44 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link local: (not bound)
Fri Oct 10 09:05:44 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link remote: [AF_INET]3.65.167.143:41691
Fri Oct 10 09:05:59 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: [UNDEF] Inactivity timeout (–ping-restart), restarting
Fri Oct 10 09:05:59 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: SIGUSR1[soft,ping-restart] received, process restarting
Fri Oct 10 09:06:04 2025 daemon.warn openvpn(rms_kZEnC567luRo2nKC)[18631]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Oct 10 09:06:04 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: TCP/UDP: Preserving recently used remote address: [AF_INET]3.69.106.81:41691
Fri Oct 10 09:06:04 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link local: (not bound)
Fri Oct 10 09:06:05 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link remote: [AF_INET]3.69.106.81:41691
Fri Oct 10 09:06:20 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: [UNDEF] Inactivity timeout (–ping-restart), restarting
Fri Oct 10 09:06:20 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: SIGUSR1[soft,ping-restart] received, process restarting
Fri Oct 10 09:06:25 2025 daemon.warn openvpn(rms_kZEnC567luRo2nKC)[18631]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Oct 10 09:06:25 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: TCP/UDP: Preserving recently used remote address: [AF_INET]3.65.167.143:41691
Fri Oct 10 09:06:25 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link local: (not bound)
Fri Oct 10 09:06:25 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link remote: [AF_INET]3.65.167.143:41691
Fri Oct 10 09:06:40 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: [UNDEF] Inactivity timeout (–ping-restart), restarting
Fri Oct 10 09:06:40 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: SIGUSR1[soft,ping-restart] received, process restarting
Fri Oct 10 09:06:45 2025 daemon.warn openvpn(rms_kZEnC567luRo2nKC)[18631]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Oct 10 09:06:45 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: TCP/UDP: Preserving recently used remote address: [AF_INET]3.69.106.81:41691
Fri Oct 10 09:06:45 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link local: (not bound)
Fri Oct 10 09:06:45 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link remote: [AF_INET]3.69.106.81:41691
Fri Oct 10 09:07:00 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: [UNDEF] Inactivity timeout (–ping-restart), restarting
Fri Oct 10 09:07:00 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: SIGUSR1[soft,ping-restart] received, process restarting
Fri Oct 10 09:07:10 2025 daemon.warn openvpn(rms_kZEnC567luRo2nKC)[18631]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Oct 10 09:07:10 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: TCP/UDP: Preserving recently used remote address: [AF_INET]3.65.167.143:41691
Fri Oct 10 09:07:10 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link local: (not bound)
Fri Oct 10 09:07:10 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link remote: [AF_INET]3.65.167.143:41691
Fri Oct 10 09:07:25 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: [UNDEF] Inactivity timeout (–ping-restart), restarting
Fri Oct 10 09:07:25 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: SIGUSR1[soft,ping-restart] received, process restarting
Fri Oct 10 09:07:35 2025 daemon.warn openvpn(rms_kZEnC567luRo2nKC)[18631]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Oct 10 09:07:35 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: TCP/UDP: Preserving recently used remote address: [AF_INET]3.69.106.81:41691
Fri Oct 10 09:07:35 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link local: (not bound)
Fri Oct 10 09:07:35 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link remote: [AF_INET]3.69.106.81:41691
Fri Oct 10 09:07:48 2025 daemon.warn wpa_supplicant[3200]: wlan0: Undefined secondary channel: drop OBSS scan results
Fri Oct 10 09:07:50 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: [UNDEF] Inactivity timeout (–ping-restart), restarting
Fri Oct 10 09:07:50 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: SIGUSR1[soft,ping-restart] received, process restarting
Fri Oct 10 09:08:10 2025 daemon.warn openvpn(rms_kZEnC567luRo2nKC)[18631]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Oct 10 09:08:10 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: TCP/UDP: Preserving recently used remote address: [AF_INET]3.65.167.143:41691
Fri Oct 10 09:08:10 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link local: (not bound)
Fri Oct 10 09:08:10 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link remote: [AF_INET]3.65.167.143:41691
Fri Oct 10 09:08:25 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: [UNDEF] Inactivity timeout (–ping-restart), restarting
Fri Oct 10 09:08:25 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: SIGUSR1[soft,ping-restart] received, process restarting
Fri Oct 10 09:08:45 2025 daemon.warn openvpn(rms_kZEnC567luRo2nKC)[18631]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Oct 10 09:08:45 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: TCP/UDP: Preserving recently used remote address: [AF_INET]3.69.106.81:41691
Fri Oct 10 09:08:45 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link local: (not bound)
Fri Oct 10 09:08:45 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link remote: [AF_INET]3.69.106.81:41691
Fri Oct 10 09:09:00 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: [UNDEF] Inactivity timeout (–ping-restart), restarting
Fri Oct 10 09:09:00 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: SIGUSR1[soft,ping-restart] received, process restarting
Fri Oct 10 09:09:40 2025 daemon.warn openvpn(rms_kZEnC567luRo2nKC)[18631]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Oct 10 09:09:40 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: TCP/UDP: Preserving recently used remote address: [AF_INET]3.65.167.143:41691
Fri Oct 10 09:09:41 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link local: (not bound)
Fri Oct 10 09:09:41 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link remote: [AF_INET]3.65.167.143:41691
Fri Oct 10 09:09:57 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: [UNDEF] Inactivity timeout (–ping-restart), restarting
Fri Oct 10 09:09:57 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: SIGUSR1[soft,ping-restart] received, process restarting
Fri Oct 10 09:10:37 2025 daemon.warn openvpn(rms_kZEnC567luRo2nKC)[18631]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Oct 10 09:10:37 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: TCP/UDP: Preserving recently used remote address: [AF_INET]3.69.106.81:41691
Fri Oct 10 09:10:37 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link local: (not bound)
Fri Oct 10 09:10:37 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link remote: [AF_INET]3.69.106.81:41691
Fri Oct 10 09:10:48 2025 daemon.warn wpa_supplicant[3200]: wlan0: Undefined secondary channel: drop OBSS scan results
Fri Oct 10 09:10:52 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: [UNDEF] Inactivity timeout (–ping-restart), restarting
Fri Oct 10 09:10:52 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: SIGUSR1[soft,ping-restart] received, process restarting
Fri Oct 10 09:12:12 2025 daemon.warn openvpn(rms_kZEnC567luRo2nKC)[18631]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Oct 10 09:12:12 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: TCP/UDP: Preserving recently used remote address: [AF_INET]3.65.167.143:41691
Fri Oct 10 09:12:12 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link local: (not bound)
Fri Oct 10 09:12:12 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link remote: [AF_INET]3.65.167.143:41691
Fri Oct 10 09:12:28 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: [UNDEF] Inactivity timeout (–ping-restart), restarting
Fri Oct 10 09:12:28 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: SIGUSR1[soft,ping-restart] received, process restarting
Fri Oct 10 09:13:48 2025 daemon.warn wpa_supplicant[3200]: wlan0: Undefined secondary channel: drop OBSS scan results
Fri Oct 10 09:13:48 2025 daemon.warn openvpn(rms_kZEnC567luRo2nKC)[18631]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Oct 10 09:13:48 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: TCP/UDP: Preserving recently used remote address: [AF_INET]3.69.106.81:41691
Fri Oct 10 09:13:48 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link local: (not bound)
Fri Oct 10 09:13:48 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: UDP link remote: [AF_INET]3.69.106.81:41691
Fri Oct 10 09:13:51 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: [teltonika-vpn-kZEnC567luRo2nKC] Peer Connection Initiated with [AF_INET]3.69.106.81:41691
Fri Oct 10 09:13:51 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: TUN/TAP device tun_c_rms_kZEnC opened
Fri Oct 10 09:13:51 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: net_iface_mtu_set: mtu 1500 for tun_c_rms_kZEnC
Fri Oct 10 09:13:51 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: net_iface_up: set tun_c_rms_kZEnC up
Fri Oct 10 09:13:51 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: net_addr_ptp_v4_add: 192.168.255.10 peer 192.168.255.9 dev tun_c_rms_kZEnC
Fri Oct 10 09:13:51 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: /etc/openvpn/updown.sh tun_c_rms_kZEnC 1500 1553 192.168.255.10 192.168.255.9 init
Fri Oct 10 09:13:51 2025 daemon.notice openvpn(rms_kZEnC567luRo2nKC)[18631]: Initialization Sequence Completed
Fri Oct 10 09:13:55 2025 daemon.info dnsmasq[16637]: exiting on receipt of SIGTERM
Fri Oct 10 09:13:55 2025 daemon.info dnsmasq[19641]: Connected to system UBus
Fri Oct 10 09:13:55 2025 daemon.info dnsmasq[19641]: started, version 2.85 cachesize 150
Fri Oct 10 09:13:55 2025 daemon.info dnsmasq[19641]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Fri Oct 10 09:13:55 2025 daemon.info dnsmasq[19641]: UBus support enabled: connected to system bus
Fri Oct 10 09:13:55 2025 daemon.info dnsmasq-dhcp[19641]: DHCP, IP range 192.168.10.100 – 192.168.10.249, lease time 12h
Fri Oct 10 09:13:55 2025 daemon.info dnsmasq[19641]: using only locally-known addresses for domain test
Fri Oct 10 09:13:55 2025 daemon.info dnsmasq[19641]: using only locally-known addresses for domain onion
Fri Oct 10 09:13:55 2025 daemon.info dnsmasq[19641]: using only locally-known addresses for domain localhost
Fri Oct 10 09:13:55 2025 daemon.info dnsmasq[19641]: using only locally-known addresses for domain invalid
Fri Oct 10 09:13:55 2025 daemon.info dnsmasq[19641]: using only locally-known addresses for domain bind
Fri Oct 10 09:13:55 2025 daemon.info dnsmasq[19641]: using nameserver 8.8.4.4#53
Fri Oct 10 09:13:55 2025 daemon.info dnsmasq[19641]: using nameserver 8.8.8.8#53
Fri Oct 10 09:13:55 2025 daemon.info dnsmasq[19641]: using only locally-known addresses for domain lan
Fri Oct 10 09:13:55 2025 daemon.info dnsmasq[19641]: reading /tmp/resolv.conf.d/resolv.conf.auto
Fri Oct 10 09:13:55 2025 daemon.info dnsmasq[19641]: using nameserver 192.168.1.1#53
Fri Oct 10 09:13:55 2025 daemon.info dnsmasq[19641]: read /etc/hosts - 4 addresses
Fri Oct 10 09:13:55 2025 daemon.info dnsmasq[19641]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Fri Oct 10 09:13:55 2025 daemon.info dnsmasq-dhcp[19641]: read /etc/ethers - 0 addresses
Fri Oct 10 09:13:56 2025 daemon.info dnsmasq[19641]: read /etc/hosts - 4 addresses
Fri Oct 10 09:13:56 2025 daemon.info dnsmasq[19641]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Fri Oct 10 09:13:56 2025 daemon.info dnsmasq-dhcp[19641]: read /etc/ethers - 0 addresses
I cannot attach a larger system log file due to new forum users limitation, but i can provide it if necessary.
Is this some know issue? Is there some way to make it work as expected?
