It has (at least in specs) internal MicroSD slot and according specs it’s to Samba use.
Could it be used to another things like periodically pulling configs from devices behind RUT206 and save those configs to MicroSD?
Without knowing or owning this device: the microsd card will be mounted like a /dev/sda kind of device in the operating system, so i don’t see a reason why storing stuff wouldn’t work. It will require custom (bash) scripts i presume.
Thanks, I was thinking same. Yeah, custom bash script is need, but it’s easy.
So, I need order one and test ![]()
Hello @timnis,
Could you please confirm if your issue has been resolved, or if you still need any assistance?
