RUT200 WIFI not working after upgrading to RUT2M_R_00.07.05
I have a RUT200 device which was working before firmware upgrade.
I have upgraded the firmware to the new version of RUT2M_R_00.07.05 ; after that all is working apart from wifi wireless interface which cannot be found with a scan, this occurs both on new generation smartphone and also with a common HP PC.
Is there any solution?
Thank you
Luca
Could you please reset the device and let me know if the issue persists?
If it does, please share some of the system logs from System → Maintenance → Troubleshoot page → ‘Show’ system logs. Before sharing the logs, make sure to hide any sensitive information, such as public IP addresses, that may potentially appear in the logs.
Dear AndzejJ,
after a reboot the wifi service started. However I am not sure that it was the first reboot. I will observe in the meaning.
Thank you!
Luca Capisani
