Rut200 : ports management
I’ve a RUT200, FW up to date and default parameters.
My home security system don’t communicate with the central system.
Their hotline tell me that their protocol is using ports 30100-30110.
Are those ports open by default or should I do something? And what?
Thank you for your help
I’m sorry.
I really need some help or guidance to understand my issue and the (right) way to solve it.
Thank you
Hi…
Just arrive here, few minutes, ago.
Standard firewall have all port block by default, from wan to lan. So… You need to do a forward rule for this range of ports in your device. (tcp? udp?)
