Rut200 not able to reach vpn client but works other way round
I have my office LAN on 192.168.1.0/24 and it is connected to the rut200 via VPN through RMS.
The remote rut 200 has a LAN network on 192.168.2.0/24 I also have a laptop there on that network running ubuntu on 192.168.2.31/24
I setup a VPN hub and routes there it works pretty well for access to the remote network.
I am able to ping the rut 200 and the laptop from my office network but not the other way around.
I am running an ftp server in my office and I need to transfer files from remote network to the office network.
I tried adding a route to the vpn hub back the way but didn’t work.
What else should I look at to allow this to work?
Hi hadwll,
There are few things to check.
  1. Make sure that the devices are on the latest firmware versions.
  2. In RMS VPN, under Routes, enable LAN forwarding for both devices. Then add the respective routes to allow LAN connectivity.
  3. Disable firewall on end devices as this might cause any communication to reach/reply.
  4. Can you try to add the PC on office LAN as RMS VPN client instead of directly connecting it to RUT200?
Let me know your results. Thank you.
