RUT200 lose mobile connection
I’m using a RUT200 to have a connection to a server with a mobile connexion.
On Status/Network/Mobile, the operator state is ‘roaming’.
Very often sometimes each 60 seconds, it seems it change of Operator.
I have:
Operator: N/A
Operator state: Limited service
Data connection state: Connected
Then
Operator: N/A
Data connection state: Disconnected
Then
Operator: N/A
Operator state: Denied
Then
Operator: ABCDEF
Operator state: Roaming
Then
Operator: N/A
Operator state: Searching
Then
Operator: GHIJKL
Then
Operator: GHIJKL
Is it possible to select only one operator ? I don’t want it to change so often.
Thank you.
Best Regards
To manually select your preferred operator, go to Network > Mobile > Network selection in WebUI. From there, you can specify the operator you want to connect to. More detailed steps can be found here.
Hope this helps!
Thank you for answering.
It has not solved my problem. I have contacted the mobile operator…
Finally, the problem was that the APN was configured, but no name was created for this configuration.
Best Regards
I’m glad to hear the problem has been resolved!
Please feel free to reach out on the forum if you have any further questions, concerns, or solutions to share.
